Advice Needed TBS 5925
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
Convinced after a couple of hours that smartdvb is far superior to dvbdream
but for the life of me cannot find the plugin folder, anyone help?
blademedia
Sky
I think when you install you have to choice the option to run with admin privileges give that a go and see what happens
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Couple of times before this has happened so now after install go to the normal install location ie: c:\program files\SmartDVB and 'copy' the whole 'Plugins' folder.
Follow the path.............c:\users\yourname\appdata\local\smartdvb\plugins and 'paste' (overwrite if need) your copied 'Plugins' folder here.
If open, close the SmartDVB program and reopen it..... click the'Plugins' icon and should result as:-
The topic is covered on the SmartDVB site if need.
blademedia
Sky
16 APSK channels, locking a couple at 21E but no solid picture, do I need more signal ? different codec filters thanks
blademedia
Sky
Looks like mature content on this one :eek:?
blademedia
Sky
More adult @ 21E 11218 13333 H 16APSK
blademedia
Sky
blademedia,
Did you buy a fan case for your TBS5925?
Thx
Hello moonbase, ive bought Perspex bolts and fan for making my own, will try and make it up tomorrow and post pictures up
Sat1969
CM 90cm
London
Blademedia,
Have you made the fan enclosure for the TBS 5925 ? Pictures ?
