TBS 6925 PCi Card with hardware blind scan in DVB-S2 and DVB-S
starman345 said:
Lately I"ve been using the TBS 6925 mostly
What is the blind scan like? How fast to scan a whole satellite? and how much does it miss? Also can you control the scanned symbol rates?
aceb
Prof Tuner 7301 /
Sussex
Thanks Starman, I've certainly not had any complaints about the card and as you say the blind scan app is excellent. I've not really looked to see how many 16&32APSK signals are about in Europe but it does seem to be the only thing I miss out on. I do have one issue with mine, changing channel within DVB Dream doesn't always work first time if the new channel is empty or very weak, not sure if this is a driver or app issue but it's hardly a show stopper.
starman345
10' c/ku dish Bullseye II feed, Gbox 3000, 90cm Dish, SG-2100,
Prof 7301 PCI
TBS 8922 PCI
TBS 6925 PCI-E
New Brunswick Canada
Well it depends, the TBS blind scan tool is not very fast however it is thorough. I have seen it take an hour to scan both vertical and horizontal polarities on a satellite. Also, there is no realtime feedback as the scan is taking place, you can't actually see what freq it is scanning at the moment. Scanned in frequencies are added to a list and shown on the screen as they are logged. I've scanned some satellites in as little as 20 minutes with the TBS tool but that is still a long time..
On the other hand, the 6925 is much quicker with BLScan (and now the new GUI version Easy BlindScan) Depending on the satellite, I would guess scans take between 5 and 15 minutes with the average around 8-10 minutes. Accuracy is very good, depending on dish aiming, lnb quality, etc.
No in the TBS blind scan tool, yes in BLScan, most settings are configurable in BLScan, including step rate, freq range, ini output format, min/max SR, and a host of other settings.
Received the TBS 6925 today, just installed it to have a play.
So far, just checked the Italian ACM mux on AB1. Scanning it gives me six channels in the clear (nothing else on the TP at present, possibly different channels appear at different times).
Canal One
Mediaset Extra
HSE 24
Real Time
QVC
LA5
TBS Recorder looks interesting, gives plenty of channel statistics.
Yet to try blind scanning, SR limits etc.
starman345
Prof 7301 PCI
TBS 8922 PCI
TBS 6925 PCI-E
Have you had a chance to try the card with CrazyScan? It works very well with it, motor control, DiSEqC1.2, and 22khz control
Will try it soon starman. 10E is good for feeds. Just need to read the info files in the BS folder to aquaint myself with Crazyscan.
I don't need DiSEqC motor control, I use a separate positioner (Echostar AD3000).
starman345
Prof 7301 PCI
TBS 8922 PCI
TBS 6925 PCI-E
Just did a comparison scan on Anik F3 @118.8W with the TBS BS tool v3.0.0.5 and BLScan
TBS tool found 15 transponders in 35:30 minutes, BLScan found 15 transponders in 6:47 minutes. This was the C Band side of AnikF3 that was scanned. I should also mention the TBS 6925 scanned in two transponders with an SR of 923 on this satellite, both scanned successfully with TBS tool and BLScan.
Here's a blind scan I did on Eutelsat W2A 10E using BLScan with the TBS 6925.
Time taken as shown in the Report file was ~642s, a little over 10 minutes. TP's checked were without the 9E frequencies to clutter up the results. I have no other hardware blind scan capabilities, so I don't have any means to check whether the time taken was good or otherwise.
It found a 16APSK feed, also an NBC_QPSK channel, not sure what flavour that is?
I'm using a WIN7 x64 OS.
  • BLScan 10E.txt
aceb
Prof Tuner 7301 /
Sussex
I wondered this too when I started using BLScan and this is the answer I got back from Crazycat.
Crazycat said:
NBC_QPSK is DVB-S2/QPSK in DVBDream transponder ini subformat.
QPSK modulation with LDPC/BCH FEC.
What was the step size?
Step=4. Haven't tried any other spacings yet.
  • BLScan. Setup.txt
A mistake in the Setup txt file - the search interval 1 lines for min and max vert sweep was the same as for the hor (search interval 0).
I forgot to edit it before posting after using that setup for another satellite.
So 10 minutes in 4MHz steps but you are only scanning verticals?
No, both polarities.
@ aceb
OK, thanks. Nothing weird about it then.
I couldn't tell from that config file. 10 minutes to scan a whole satellite in 4MHz steps is pretty respectable for any blind search receiver. Go much faster than that and they'll start missing stuff. 4MHz is OK 99% of the time but will miss things when you have ultra low symbol rate feeds right next to one another.
Polarity is defined by 0=H, 1=V
; Search interval 0 definition
; Polarisation - 0;H;Horizontal, 1;V;Vertical, 2;L;Left, 3;R;Right
[Scan0]
Pol=H
; Search interval 1 definition
[Scan1]
Pol=V
Yes, I'll try a step of 2MHz next time and compare results.
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
hi, i am thinking of getting this as my next project (always had sat boxes), and as a way to watch 422 mpeg 4 feeds. have you managed to watch any? also its unclear from the specs if it has lnb short protection, thanks for the info so far!
Watching MPEG4 4:2:2 feeds will depend on the codecs you have with your chosen DVB viewing application.
I haven't as yet tried to find any using the 6925 card, but I had no problem with my Hauppauge WINTV HD card and DVBViewer Pro. Can't remember which codec I was using at the time. No doubt the 6925 will have no problem with those feeds.
As for the 6925's LNB short circuit protection, I would be surprised if that wasn't a feature. The only pci card I had that didn't have protection was a certain version of a Skystar 2 card - as I found out one day.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Looks like the thread already exists regarding the TBS 6925 ...
Having just heard about it for the first time on aceb Cband setup thread ..
Can anyone tell me where this card can be obtained and at what sort of monies ?
Just searched on ebay ..but came back with nothing ..
The only thing I found was this list of features posted on another forum ..
so far that is ..
I'll definately read the whole thread ..and do a bit of digging for my own benefit.
1 quick question though ..
Is it only used with its own proprietory software ..or is it supported by DVBviewer ?
I have a genuine paid for version of this software ..
Feature 10 . in the list suggests it is ..but would appreciate some feedback from users..
rgds
VS
Main Features:
1. DVB-S2/S Transponders Receiving
2. CCM, VCM and ACM mode support
3 .Support Multiple Transport Stream Receiving
4. Support Generic Stream capture
5. Transponders blind scan
6. Up to 190 Mbit/s channel bit rate capture
7. Wide range symbol rates support, from 200Ksps to 45Msps
8.High-speed Data download via Satellite
9. Windows 7 Media Center compatible
10.Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, TSreader…
Specifications:
1.Receiving Frequency: 925~2175 MHz Tuning Range
2.Input level: -69~ -23dBm
3.DVB-S2/DVB-S DIRECTV 8PSK QPSK 16APSK 32APSK Demodulator
4. 8PSK /QPSK/16APSK/32APSK mode
5. Symbol Rates:
DVB-S2 QPSK: 200Ksps~45 Msps
DVB-S2 8PSK: 200Ksps~45 Msps
6. Code Rates:
DVB-S: 1/2, 2/3, 3/4, 5/6, 7/8
DVB-S2 QPSK: 1/4,1/3,2/5,1/2,3/5,2/3,3/4,4/5,5/6,8/9,8/10
DVB-S2 8PSK: 3/5,2/3,3/4,5/6,8/9,9/10
16APSK: 2/3,3/4,4/5,5/6,8/9,9/10
32APSK: 3/4,4/5,5/6,8/9,9/10
7. Automatic Acquisition Range: ±10MHz
8. DiSEqC 2.x compliant
9. PCI Express interface
10. Low profile size
