New Crazyscan
The latest Crazyscan application allows PLS (Physical Layer Scrambling) descrambling of Mediaset transponders on 13E, together with the RAI multistream TP's bound for the Italian regional terrestrial services on 5W
You can download the new files from -http://sourceforge.net/projects/crazyscan/files/
Details below from Rick's at -http://rickcaylor.websitetoolbox.com/post/Crazyscan-BLScan-Software...Post-Files-Here-5344588?trail=45
StreamReaderEx-BDA 1.1.0.1036 -
•New function PLSSel - PL-descrambler control (mode and 18-bit code). New function realized for all supported STV090x-based devices. Detailed info given in DVB-S2 EN 302 307 standard - p.30, point 5.5.4, Physical layer scrambling.
CrazyScan 1.0.1.52 -
•Control of DVB-S2 PL descrambler in carrier search dialog window. There is possibility to select mode of code (Root, Gold and Combo) and code (1-262143). If specify PL = 0, then auto-search of code (full range 1-262143) will be enabled. For search speed-up it is desirable to select DVB-S2 modulation standard, also select MinSR >> 1000 ks/s, if carrier on the spectrum has big width (i.e. SR>10000 ks/s).
P.S. StreamReaderEx-SDK updated.
P.P.S. Mediaset multistream transponders on Hotbird 13E have PL = Root, 8.
Another found multistreams on 5W: -http://forum.satkurier.pl/viewtopic.php?f=13&p=669133#p669133
From the TBS6925 section at -www.tbsdtv.com -
List of frequiencies that can be received
13°E
- 11,334 GHz, pol. H, SR: 27500, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 8, MIS: 1, 2 (Mediaset)
- 11,373 GHz, pol. H, SR: 27500, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 8, MIS: 1, 2 (Mediaset)
- 11,432 GHz, pol. V, SR: 27500, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 8, MIS: 1, 2 (Mediaset)
- 12,539 GHz, pol. H, SR: 27500, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 8, MIS: 1, 2 (Mediaset, copy of 11,334 GHz, pol. H)
5°W
- 11,012 GHz, pol. V, SR: 30000, FEC: 3/5 (DVB-S2/8PSK), PLS Mode: Root + 16416, MIS 2, 3, 11 (RAI)
- 11,179 GHz, pol. V, SR: 30000, FEC: 3/5 (DVB-S2/8PSK), PLS Mode: Root + 16416, MIS 4, 5, 12 (RAI)
- 11,637 GHz, pol. V, SR: 30000, FEC: 3/5 (DVB-S2/8PSK), PLS Mode: Root + 16416, MIS 1-6 (RAI)
- 11,675 GHz, pol. H, SR: 30000, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 16416, MIS 7-16 (RAI)
- 12,585 GHz, pol. H, SR: 27500, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 8, MIS 1 (data transmission, OpenMux IP Gateway)
- 12,606 GHz, pol. V, SR: 29900, FEC: 2/3 (DVB-S2/8PSK), PLS Mode: Root + 8, MIS 1, 2 (Mediaset)
Using the Root numbers above in Crazyscan, I can open the appropriate channels specified above. Some are FTA anyway where they are normally transmitted on e.g 13E, others (for instance RAI Premium) are normally encrypted on 13E, but are FTA on 11.179v using Root + 16416 on MIS 4.
