technomate 5500 or Monoblock users - pls help
manikm
on your boxes when you 1st turned it on, did you get NO SIGNAL?
I just cannot get this to work with my Monoblock
I just get no signal...
On the receiver if i goto to the channel setup screen, along the bottom are two bars, one says Strength, the other says "quality" - "Signal" is on 78 and fluctuates between 75 - 80 depening on which transponder i choose, but "Quality" is always on 10.
What do yours say, and was this ever a problem for you?
Please see my other thread for further info....im stuck.
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=9923
Thanks for any advice.
petchletch
I will be setting up the same system for someone next week - will let you know the results - Tecnomate say Quality" must always be above 50.
Maybe it's your Disecq settings - please let me know the disecq settings you have etc
He solved the probelm in the end petchletch.
