Sjohnson
- Apr 29, 2022
- Age
- 36
- Tivusat Telesystem receiver, 60cm dish, pointed at Hotbird 13e
- Kent
Hi everyone!
Have some trouble with my Tivusat Italian TV set up on Hotbird 13E and looking for some advice.
Bought a 60cm dish and Tivusat box for my house in Kent and had it installed by a local aerial company. All was working fine, but a few hours after the guy left, the Italian channels all started to be glitchy and unwatchable. Yet, all the Arabic channels are fine (eg: Alalam HD). Getting a signal quality of about 43% across all channels, including Arabic and Italian.
Guy came back and moved something - and still the same. All Italian channels unwatchable but Arabic ones fine.
Is there a problem with the dish set up, do you think? The guy who fitted it thinks it's the dish or the LNB - I just find it strange it all worked ok at the beginning, then stopped. But all the Arabic channels are OK but not the Italian. Any help or advice gratefully received!
