Toshiba VCR - NV780 - Red light on front
and I was hoping to sit down with a film tonight.
The forum which used to offer help with VCR repairs has disappeared from the net.
Any pointers as to which component(s) might be causing this ?
The only NV series VCRs I know of are the Panasonics CH. May be wrong though.
LED on only points to a PSU fault on those. Check the electrolytics - the usual suspects.
Of course I got the model number wrong (V-730), but it is a Tosh though.
Can't find anything online for that model, and all my old service sheets are stacked behind the garage. I keep meaning to shove it all in the loft, but something would have to go from up there :-doh2
I'll see if there's anything there when it's light.
Nothing listed for that problem in stock faults I have for the V730 or equivalent models, maybe someone may turn up something eventually.
Meanwhile I'll send you the circuit diagram CH if you fancy a bit of fault finding :eek:
Cheers Will take a look tomorrow
