I remember some tests from Tarragona (100Km => Nonaspe Signal) with antenna of 180cm of primary focus with LNB Invacom C120 and nothing of anything for the beam UK, the tests realized an installer with equipment of measurement in the middle of the street Amount) and nothing (nones) when they began to migrate the channels to the UK beam.
With a petal antenna 240cm => 180cm real performance, with an LNB for offset antennas that does not see the whole antenna, you can only tune tp's for Europe, nothing more (surely).
That you tune 26ºE channels, it is normal, with 50-60cm of antenna you have enough that satelite (the beam points to another zone).
As colleagues indicate, adjust the antenna to 28'xºE by tuning channels of the European beam, such as ....
TVC News +1 11464 H 22000 5/6
TRT World 11479 V 22000 5/6
To compare, mount the Maxview antenna 80x58cm with the same LNB Revez (0'1d.B, surely tune the channels commented with the same level of signal, if so, bad symptom, says much of the performance Antena 240 petalos + LNB Offset (in Primary focus antenna)
Then if you want, already located the position, you can play to search channels of the UK beam.
TruTV + 1 11307 V 27500 2/3 (plus signal)
E4 10729 V 22000 5/6.
Recuerdo unas pruebas desde Tarragona (100Km =>Nonaspe Señal) con antena de 180cm de foco primarion con LNB Invacom C120 y nada de nada para el haz UK, las pruebas las realizo un instalador con equipos de medida en medio de la calle (la que monto) y nada (nones) cuando empezaron a migrar los canales al haz UK.
Con una antena de petalos 240cm => ni 180cm rendimiento real, con un LNB para antenas offset que no ve toda la antena, solo podras sintonizar los tp's para Europa, nada mas (seguramente).
Que sintonices canales de 26ºE, es normal, con 50-60cm de antena tienes suficiente ese satelite (el haz apunta a otra zona).
Como indican los compañeros, ajusta la antena a 28'xºE sintonizando canales del haz Europeo, como ....
Para comparar, monta la antena Maxview 80x58cm con el mismo LNB Revez (0'1d.B, seguramente sintonizaras los canales comentados con el mismo nivel de señal, si es asi, mal sintoma, dice mucho del rendimiento Antena 240 petalos + LNB Offset (en antena foco primario)
Luego si quieres, ya localizada la posicion, puedes jugar a buscar canales del haz UK.
TruTV+1 11307 V 27500 2/3 (mas señal)
