- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
Not really surprising - BBC3 HD hasnt launched yet!
That's why I took CBBC HD as example ;)
But some HD services never have been active on 27.5W though they have an entry in the PAT and SDT like STV HD, UTV HD. Besides, there is no bandwidth left for additional HD services ( <5Mbps null packets).
no, it isn'tI presume BBC RB HD is still carried on here too?
The Technomate works flawlessly and doesn't seem to be affected by changes in the transmissions (scrambling the PMT, etc.) that cause problems for other receivers.
Does anyone know if there is a PVR receiver that is equally reliable? - Being used to Sky HD I will have difficulty adapting to not being able to record programmes in the same fashion. Lack of EPG will also be a problem I think!
I have been given a Technomate TM500. Does anyone know if this will work on this sat? If not, what is the cheapest box that will?
Do you mean the "BBC One HD" caption or something different? The BBC One HD one says "BbC One HD cannot yet show your local programmes...". Next time you see it can you please get a jpg of it please? I was under the impression that the network bbc1 had London at weekends, for the two five minute bulletins, with BBC news Channel at 1830 on weekdays, not sure about 2225 on weekdays.Just an update, BBC One is no longer BBC One London. It was BBC One Network when checking on the local opt outs diuring the news. Cut to the BBC Holding card of the BBC logo moving
Whats the difference with the M2 version?
And, at Breakfast is it not London?
the next opt-out is at 1810 on Sunday. If someone can check, would be most grateful to know what is there. Thanks.
BTW which news bulletin were you checking - ie what time of day?
Interesting, didn't realise that. Obviously as it's temporary and the DSAT backup is a DR feed if BT's main MPLS TS distribution fails they are happy to loose it for a particular site loosing both it's two primary MPLS derived inputs.no, it isn't
Thanks. Can you please check tomorrow to see what goes out during Breakfast and at 13:30? Also, there is the 1958 local window - after the headlines just before Eastenders, there is a weather forecast on HD - would be interested to know what happens then. mI wonder what goes out during Inside Out?BBC One (not regional or HD versions) carries BBC London on weekends and the BBC news channel at 18:30 and 22:30 indeed. It is still BBC network as I've checked a day ago
I'm a night guy so can't really check Breakfast but I can do the rest if I remember sure.Thanks. Can you please check tomorrow to see what goes out during Breakfast and at 13:30? Also, there is the 1958 local window - after the headlines just before Eastenders, there is a weather forecast on HD - would be interested to know what happens then. mI wonder what goes out during Inside Out?
Thanks.
