up coming launch abs 2 on 75e
abs 2 arrive to home
74.7 east will be start testing soon
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Solly has abs 2 started testing yet?
it not start testing yet
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Lexzie
TBS 5925 USB-tuner
The Netherlands
ot best video of footprint
The shown C- and Ku-footprint in that video must be the combined coverage of ABS-1, 2 and 3. One satellite can never cover a large region like that.
Yesterday evening's TLE had ABS 2 at 74.9 East moving East, so ABS-2 should be together with ABS-1 at 75.0 East now.
it start testing near 12 march
tempo
47.5N, 42.2E / Russia
The first transponders of ABS-2 were activated today in the morning. They used a quick test of unmodulated carriers and then loaded transponders with digital signal. Here they are:
10971 H 12539 8/9 8PSK
10998 H 12616 8/9 8PSK
11031 H 12539 8/9 8PSK
11058 H 12539 8/9 8PSK
11665 V 26077 8/9 8PSK
We have a strong signal in the rest of Russia and little weaker in Central Asia countries.
I don't sure about Europe (if look at footprint map), but you could try receive these signals.
Kveys
Southern Finland
Quite strong also in Finland. More than 15dB (125 Gibby). No changes yet on C-band as I just blindscanned it and same levels as before. Any idea what/when/are there any C-band changes in future..? A-beam strong here but B-beam weak (2.3m mesh). This new bird will use Global, east-hemi and west hemi and surely east hemi looks like bye bye for channels, if it will be use..?
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
A lot of channels at:
10969H 17141SR 11.4dB
11029H 17141SR 12.8dB
11603V 43200SR 14.0dB
11663V 42783SR 12.7dB
There are more txp active but no channels there
10998H,17245,2/3,S2/8psk-we have on this transponder a T2-MI PLP-0.We can see the content with 4T2 Content Analyzer.
next week abs 2 start switch transponder from abs 1 to abs 2
telecommunications satellite ABS second During the tests were confirmed by the calculated parameters of the satellite.
Successful tests allow the movement of the satellite on ABS 1 ABS 2, in accordance with the original plan. The commercial launch ABS 2 is scheduled for Thursday, March 27, 2014.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Will those transponders on ABS 1 having a Northern beam still continue to do so if they are transferred to ABS2?
I am asking because I could always receive these Transponders up to now, but can't receive any new Transponders from ABS 2 using the Russian Beam, or putting it in simpler terms, is ABS 2 going to have any Pan European Beam?
adonis1
adonis1
We gonna loose (South area) all Russian channels from this position with ABS2 Russian Footprint .
After channels immigration , ABS1 gonna be transfer at 159.0° E .
adonis1
Ok , thats the bad news with Russia Beam of ABS 2 .
The good ? news are , that C band channels of ABS2 are gonna be much easier to get them .
did you get same transponder from abs 2 low ku band ?
adonis1
Not even one transponder , of ABS2 , but I get all transponders of ABS1 .
So soon , i will not have receprtion of russian beam from 75E .
the table say start tomorow both satellite abs1/2
it start disconnect abs 1 from 2.4 and 10;.4
