- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
Finally, we see some light at the end of the tunnel! I have some data in this collage
Somebody will be along soon to claim such a dimension does not exist on an offset dish.The dish is an offset CM 2.4m (Andrew, Raven, Skyware yet.... but it is always the same I believe).
Please note it is the receive-only version, not receive-trasmit one.
As I mentioned, I would like to test Viking 2-ports Ku-band motorised feedhorn that was originally designed for a Prodelin offset 1.8m dish but I hope in a good matching with such similar dishes.
Anyone can tell me the exact focal distance of this CM?
I am pretty sure that 1,8m offset Prodelin and 2,4m CM have exactly the same opening angle, so what was designed for Prodelin will perfectly fit to your CM. Good luck.What do you think?
Actually, you only have to place the new feed in such a way that it's phase center is co-located with the antenna's focal point. And, to perform that, the new feedarms should have some adjustment possibilities.fit the feed on the 2.4m dish in the same position as the original feed
Yes, the arms are adjustable, so the feed can be moved forward and backward for the strongest signal. Also, I believe that the scalar feed has such adjustment too.Actually, you only have to place the new feed in such a way that it's phase center is co-located with the antenna's focal point. And, to perform that, the new feedarms should have some adjustment possibilities.
Nothing. Viking provided only the feed. The additional arms and feed support are provided by SSS after examining the feed and having all dish specs and measurements. Don't believe they made a real test on the field, but the arms are largely adjustable, so I believe it is a good starting point for a fine adjustment when the feed will be positioned on the dish. Maybe an entire day tweaking the feed with the meter?The clamping arrangement of the Prodelin r/o feed is quite different to the CM version, what exactly has Viking provided for your new dish ?
If that was directed at me then unless I have misread the particular posts the o/p has confirmed Viking is supplying two port receive only components. Illustrated is a receive/ transmit feedhorn / OMT combination with filter.I think that is about feed like this
I've not ordered a Channel Master for years from any supplier willing to back up their product.I don't know.... The dish will be delivered during this week, so I will check all specs. Have you these specs and do you know if f/d is the same for both dishes? As Rimantss mentioned, Prodelin and CM seem the same, so I believe (hope) this feed can be installed without any additional issue.
