Tururu.
With respect, I don't think anyone would argue that sites like Flysat provide very comprehensive and up-to-date info, but the problem for most people is (especially with respect to avoiding misleading transponder details when the same tech specs are used on several sats), and with specific reference to vma's sat identification s/w, identifying those transponders which are unique to only one satellite - and that is not at all clear from the lists on Flysat or (AFAIK) any other general sat info site.
So is.
(Add)Finding a TP that is only used on a satellite, difficult, tomorrow if you use another satellite, the tuner compensates +/-3Mhz and is very selective, the USB tuner can compensate?
Identifying a satellite by tp's is not possible in general, the simplest example, many years ago, tune into Hispasat a receiver, without saying anything, you now put an Astra antenna at 19.2 ° East.
In the first 3 channels of Via Digital (currently Movistar. +), You now have the channels of Canal. + France, without touching anything, the receiver compensates for the small frequency difference and SR.
In my channel lists, I have more than 12,000 channels.
If you reference eg 10714 H, you have Astra at 28'2E CL4 with SR22000, at Astra at 19'2E HLG test with SR23500.
At 52E Monacosat you have 10717H3750
Another example, tp's in use in different satellites.
10718V22000- 8W
10719V22000- 7.3W
10719V27500- 13E
10721V27500- 7E
I do not know how selective the program is and the catcher.
In blind search a receiver jumps in general the canles to 1Mhz. of separation.
If you give the search data by hand, in Hispasat radio channels, you usually eat 4 tp, 2 and the tuner is much better.
The tp relation of each satellite that I use, is generated starting from the list using the blind search of the DUo2, Flysat, Lyngsat, KingofSat and lowering the relation of the 2 public webs, filter everything and I generate the mine and may be missing some.
Asi es.
(Añadido)Encontrar un TP que solo se use en un satelite, dificil, mañana puede que si lo use otro satelite, el tuner compensa +/-3Mhz y es muy selectivo, el sintonizador USB cuanto puede compensar?
Identificar un satelite por los tp's no es posible en general, el ejemplo mas sencillo, hace muchos muchos años, sintonizas en Hispasat un receptor, sin decirle nada, pones ahora una antena de Astra a 19'2ºEste.
En los 3 primeros canales de Via Digital (actualmente Movistar.+), tenias ahora los canales de Canal.+ Francia, sin tocar nada, el receptor compensa la pequeña diferencia de frecuencia y SR.
En mis listas de canales, tengo mas de 12.000 canales.
Si pones de referencia por ejemplo 10714 H, tienes en Astra a 28'2E CL4 con SR22000, en Astra a 19'2E HLG test con SR23500.
En 52E Monacosat tienes 10717H3750
Otro ejemplo, tp's en uso en distintos satelites.
10718V22000- 8W
10719V22000- 7.3W
10719V27500- 13E
10721V27500- 7E
No se lo selectivo que es el programa y la capturadora.
En busqueda ciega un receptor se salta en general los canles a 1Mhz. de separacion.
Si le das los datos de busqueda a mano, en Hispasat los canales de radio, se suele comer de 4 tp, 2 y el sintonizador es mucho mejor.
La relacion de tp de cada satelite que uso, esta generada partindo del listado usando la busqueda ciega del DUo2, Flysat, Lyngsat, KingofSat y bajando la relacion de las 2 web publicas, filtro todo y genero la mia y puede que falte alguno.
@vma
With the spectrum analyzers, you can read a tp and if it has the correct information, it identifies the
network/RED (satelite) where you are.
I do not know if the program can do the same thing, upload a sample photo.
Con los analizadores de espectro, puedes leer un tp y si este tiene la informacion correcta, se identifica la
RED (satelite) donde estas.
No se si puede hacer lo mismo el programa, subo alguna foto de muestra.
