V-sec motor for Fibo ?
Snuffer
Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Amsterdam
HI
Is there someone that can sell my a v-sec motor for fibo???
I don't have this motor in my collection and by this way pehaps i can get it.
Thanks in advance
Ron
Snuffer
Amsterdam
I have found a brand new.
Who know's with what it must turn it's no diseq 1.2 and usals also not working.
Is it 1.1. or 1.0 ??/
Ah, is that the system used by the Nokia Satscan motor? If it is, I don't think it will work under any type of DiseqC system.
Snuffer
Amsterdam
Rolfw
thanks for your reaction.
mmmm not nice.
brand new box. Fibo style etc .
perhaps by a modification or so?
Or i must by a nokia reciever what type??
Not really sure Ron, even if you are using something like a 9600 with DVB2000 software, it is still pretty fiddly to get it to work, i found some info on a PDF, another describes the actual commands used.
Snuffer
Amsterdam
_http://www.sbprojects.com/knowledge/satellite/satscan.htm
This is what i found and there must be a unit where you can control the motor with.
_http://www.satshop.com/satscan.htm
Will you share your info with me?
_http://www.so-mm.de/SATLOOK-Digisat-Pro-Akku_p240_lfr_x2.htm
This can not control i think??
This is one _www.digenius.de/download/digeniustv-IRM.pdf
and this one _web.iol.cz/dvb2000/dvb2000n_en.htm - 15k
Trust
Nijmegen Netherlands
Ron , on my Nokia 9200 (DVB 2000) is a menu (positioner) with 2 options Diseqc and VSEC .
Snuffer
Amsterdam
Hi Wim
Nice to see you here to.
Yep find that info and perhaps soon its to do by a PC programm.
There is a tool diseq 1.8 from MIBI running this commands but than you must use a PC card.
As you now i use DVBDream and have ask REL of they can built in this V-Sec commando sys. Its a simpel command.
I found out that this motor are 29 Euro so if there is a option to make it working on simple way nice to move the fibo's with it.
Also and sure verry intrested are that this motor have a mechanical end switch inside simple but verry good i will place photo from it soon on my site.
V-SEC = SATSCAN this is a rotor command0 special form Nokia.
Ron
stocksie
Echostar 2110
Technomate 5200D
Porty 2 S Crest SL65
1m H-H Lidl 80cm on TM2200
Lidl 40cm on Omnisat.
Plymouth UK
Just found a new Polarmount driven by a V-sec motor. Looks nice with the
internal micro switch limit switches etc. As previously stated it does not respond to diseqc instructions. Any "workaround" ?? TIA
