Archive7
Good idea. Will start on the design of the future ventilator.May I suggest you cool the motor with a fan ......
I don't think so. All the fans I used blow air out but never give part of it back to cool the inside. I just wish the manufacturer has provided a motor temperature sensor since it has digital design.Is it possible that when assembled the air is drawn over the motor to keep it cool?
I don't think the windings are damaged. I inspected them visually for any sign of discoloration and they all seem perfect to me.I think the windings might already have been damaged by the lack of energy transfer earlier.
You could try taking resistance measurements, and compare them agains similar windings in another motor, or you could have a go at rewinding yourself if you have an evening spare.
Exactly, but why do they run so cool?DC presumably means it's a Direct Current Motor, so there'll be a rectifying, smoothing and regulating circuit somewhere.
Fan blades at the front drawing the air over the motor, therefore it would run much cooler. if the fan runs and the blades rotate easily i doubt it is faulty.Is it possible that when assembled the air is drawn over the motor to keep it cool?
The only way to find out what is really happening inside is to attach a temperature sensor to the motor body and monitor the temperature.Fan blades at the front drawing the air over the motor, therefore it would run much cooler. if the fan runs and the blades rotate easily i doubt it is faulty.
