Visiosat bisat - loss of signal during bad weather
When you are adjusting skew are you moving the whole LNB holder or just the LNB itself? It's only the LNB that should be rotated.
Does the app give suggestions on how high each holder should be? I see there's a scale on the back.
Bamboccio
Hi I am just rotating the LNB - I am not sure about how to get that detail on the app. I am thinking to buy this beeper:
Do you think that it would help?
Yes I used something similar for many years. A video call to a phone/tablet/webcam pointing at the television can be useful too.
Terryl
Custom built PC
I think you really need a dual LNB bracket, not a triple...It put's one center and one offset, a dual bracket would work much better in this setup. That way both LNB's get full signal.
Terryl
Custom built PC
Or even replace the current LNB setup with one of these.
https://www.ebay.co.uk/itm/152665970832?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338722076&toolid=10001
Bamboccio
Thanks Terryl - I will try to fix the current setup with the beeper and then if I get some success attempt to change the bracket and LNBs. I need 4 outputs so I am not sure if the monobloc would work.
Bamboccio
I was calling my wife but her patience run short very quickly :rolleyes:
Terryl
Custom built PC
Need 4 outputs? Look down the page to the ""Inverto Black Pro 6 degree quad monoblock"" LNB section.
https://www.satellitesuperstore.com/monoblock.htm
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
As it is a multifeed dish, all LNBs somewhere in the mid range will get full signal. So no difference for the offset LNBs, as you suggest.
That's the nature of a multifeed dish: parabolic just in the vertical sense, circular in the horizontal sense (not orthogonal).
I think this bracket is fully OK, for Bamboccio's purpose.
greetz,
A33
Terryl
Custom built PC
On a triple LNB/dish setup I have measured as much as -3 dB drop on the offset LNB's total signal. Don't have the data now as this was done years ago in the lab at work.(using lab calibrated equipment)
Bamboccio
I am still not client on the skew. If I move the bottom of the LNB to the left looking at the dish I seem to loose signal - at least for hotbitd.
Peak the skew for maximum signal rather than what is theoretically correct - it's possible the probes in the LNB are not in the assumed positions.
greetz,
A33
1st sentence is correct, but when the centre LNB is aimed at your Southern-most sat then the LNBs on either side may need slightly different skew angles in "opposite directions".
That's true for my "90 West" dish with the centre LNB aimed at 0.8W and the two either side aimed at 4.8E and 5W, and so the centre LNB has virtually "zero" skew, whereas that for 4.8E is skewed very slightly "one way" and that for 5W is skewed very slightly the "other way".
Edited - my longitude is 0.41W
a33
XSAT410
Rebox RE-9000
The Netherlands
I guess that was measured on a normal, non-multifeed dish?
For a multifeed dish, like the T90, you get something like the graph here: wavefrontier t55 of toch t90
Rimantss tested it himself on a T90, and made the drawing of this post: T90 23.5 en 28.2 belangrijkste is dit de beste opstelling?
(Alas both posts without proper credit for the source of the drawing....)
Greetz,
A33
Terryl
Custom built PC
Measured on a Dish Network triple LNB dish,(Dish 1000 =110W, 119W and 129W) this was when they first came out...Sometime around 2006, the last year in the lab for me, I retired at the end of the year.
People on the West coast (well not quite to the coast) had problems with reception on 129W, found out later it was the satellites footprint, 129 was requisition from Canada, (Ciel 2) so it's footprint was not quite optimized for the US.
In the boonies of the Sierra Mountains I need a 1 meter dish for 129, then I use a DP44 switch to combine it with a standard dish 500 antenna with a DP twin LNB for 110 and 119.
Bamboccio
I had one more go and I got even more signal now. I still do not have enough on 19.2 - 11788 (although I can actually see it, the level is deemed to be too low when I do a search)
Would you be able to suggest which are the best test test channels on for 13 est as well as others for 19.2 est?
Thanks!
Going by memory these are the channels I've had issue with before:
19.2E:
12304H 27500 Sky Sport News HD
11229V 22000 BBC World HD
13E
12054H 29900 CNBC Europe HD
12520V 27500 Med Muzik
Bamboccio
Thank you - I can see all of those.
The level is indicated as circa 13db on my Technomate, I wonder if that is a decent level?
On a zone 2 dish pointing at 28.2E, an offset LNB for 19.2E, in the sunny North East:
11778V 29500: 9.0dB
12304H 27500: 10.0dB
11229V 22000: 9.5dB
The only dish I have with access to 13E is 1.2M so little point comparing :)
Bamboccio
11778V 29500: 9.0dB
11229V 22000: 9.5dB
Thank you so in theory I have a stronger signal.
12304H 12.9dB
11229V 13.2dB
On 11778V I do not have enough to see the value. I will try to adjust a bit more tomorrow.
