Vu duo motor issues
TJExcalibur
Out of this world.
Southern England
Plenty of s/h boxes on the internet. Gumtree has a few depending where you live.
TJExcalibur
Out of this world.
Southern England
The VU+ Duo is an old receiver, you can pick up some very good replacements, like the Octagon series, and many others, for a lot cheaper than you bought the VU+ Duo, and it will have a lot more features.
The Octagon SF8008 is a great box for the money.
jfrusc1
VU+ Duo
Motorised Dish
Thanks will take a look. Just need something half decent with PVR features. Even HD is fine as she doesnt sub to the movies/etc on Skylink, just the general entertainment channels.
Second hand is fine, but has to be delivered so will check eBay. My wifes a front line Nurse, so don't want to break lockdown for a Sat box. More for the sake of the seller, as we're probably higher risk :(
jfrusc1
VU+ Duo
Motorised Dish
Stuck a wanted thread in the classifieds here, maybe i'll get lucky :D
jfrusc1
VU+ Duo
Motorised Dish
World of Sat have the OCTAGON SF8008 S2X for £105. Would rather spend less given she will only use if for SkyLink but tempted to get it over and done with :D
Presume that takes external USB HDD only?
It might be able to take two since there are a pair of ports on the case
jfrusc1
VU+ Duo
Motorised Dish
Only need one. Would just prefer if it was internal to save clutter/space in comms cupboard.
jfrusc1
VU+ Duo
Motorised Dish
Hmmm doesn’t look like it has a CAM slot. Not sure I want to mess around with soft cams since I have a CW CAM and card.
jfrusc1
VU+ Duo
Motorised Dish
Wat about the Zgemma H9 Twin. £89.99 on world of sats and has CI slot and twin tuner.
TJExcalibur
Out of this world.
Southern England
It's made in China therefore not something I would buy.
jfrusc1
VU+ Duo
Motorised Dish
Fair point.
Any brands you would recommend? The Mutant HD51 was another I was looking at, but can't find it anywhere and newer version has no CI slot.
maxi_power
120cm motorised dishes
PT
Oops forgot to attach pictures of the motor :)
If the cable that is connected to the motor output to the lnb is cranked, it is also not the best way to be connected.
jfrusc1
VU+ Duo
Motorised Dish
Thanks, thats a good point. When I get up there I'll have to correct it :/
