Tururu
Assembled with recycled parts
- Jun 3, 2006
Recycled as the owner.
- North of Madrid (28703 Spain) -3Km of IKEA (40.545847, -3.612012).:-)
With a unicable LNB, you would have what you want.
You can use 8 unicable FBC tuner using a single cable from the antenna, + a delivery splitter, with this and would function unicable tuner 8, then have to configure each tuner to channel through which transmits tasting "virtual" tuner unicable.
All this with a single cable from the LNB.
Several colleagues have it, it is how they work the 2 tuners FBC has.
The extra double tuner, works with standard LNB and also with unicable, as you suggest, you would have 2 tuners more.
In short, you can tune in complete independence in polarity and satellite band tp, then you can record tp channels you have.
Comparing with the VU + DUO2 (only 4 normal tuner that can work well with unicable LN, this allows up to 16 recordings Free / Free channels, we think the same as minimum or more.
Theme channels $$$, it is limited to 7 by the emulators, the Solo4K Oscam and not used as such.
A but LNB unicable to 4, very cheap, 8 Recalled and jump to 16/32 they are expensive.
On post # 10
With LNB you have, you already have half INSTALLATION (1 LNB qua)
Only 2 satellites Maximum unicable.
2 band LNB / polaridas pointing at 2 satellites you want.
A converter / switch many outputs as you want at 2 satellites, has unicable legacy output and 2 outputs (normal LNB with 2 satellites).
Con un LNB unicable, tendrias lo que quieres, pero con peros.
Puedes usar los 8 tuner unicable FBC usando un solo cable desde la antena, + un repartidor splitter, con esto ya funcionarian los 8 tuner unicable, luego se tienen que configurar cada tuner al canal por donde transmite cada sintonizador "virtual" unicable.
Todo esto con un solo cable desde el LNB.
Varios compañeros lo tienen, es como funcionan los 2 sintonizadores FBC que tiene.
El tuner doble extra, funciona con LNB normales y tambien con unicable, como te indican, tendrias 2 sintonizadores mas.
Resumiendo, puedes sintonizar con total independencia en polaridad y banda del satelite, luego podras grabar del tp los canales que tenga.
Comparando con el VU+DUO2 (solo 4 tuner normales que pueden funcionar tambien con LNB unicable (4)), este permite hasta 16 grabaciones de canales libres/gratis, pensemos que lo mismo como minimo o mas.
Del tema de canales $, esta limitado a 7 por las emuladoras, el Solo4K usa Oscam y no se que tal.
Un pero, LNB unicable hasta 4, muy baratos, de 8 retirados del mercado y saltas a 16/32 que son caros.
Sobre el post #10
Con Los LNB que tienes, ya tienes media instalacion (1 LNB quattro)
Solo 2 satelites como maximo en unicable.
2 LNB por banda/polaridas apuntando a los 2 satelites que quieras.
Un convertidor/Conmutador de tantas salidas como quieras a los 2 satelites, tiene salida unicable y 2 salidas legacy (LNB normales con los 2 satelites).
The LNB unicable also have 1 or 2 inherited outputs for normal tuners (Legacy).
It read, only facilities with 2 satellites for unicable it is full of.
They work with 2 LNB quattro (that's right), one on each satellite and then a multiconmuatada box that makes it compatible with unicable connections.
Los LNB unicable tambien tienen 1 o 2 salidas heredadas para sintonizadores normales (Legacy).
Por lo leido, solo se de instalaciones con 2 satelites al completo para unicable.
Funcionan con 2 LNB quattro (es correcto), uno a cada satelite y luego una caja multiconmuatada que hace compatible con unicable las conexiones.
Inverto - Products - Multiswitches
EMP-Centauri - Unicable (SCR) multiswitches
Cascadable multiswitch legacy SCR unicable, DVB-T modulator transmodulator, programmable filter amplifier
Using the 2 (normal) extras tuners connected to DiSEqC.- HotBird 13E, Eurobird 9E, Amos 4W and 7W Nilesat.
You could make recordings on other satellites.
Topic solved.
Usando los 2 sintonizadores extras (normales) conectados al DiSEqC.- HotBird 13E, Eurobird 9E, Amos 4W y Nilesat 7W.
Podrias realizar grabaciones en el resto de satelites.
Tema solucionado.
Physically it is a coax cable, but it is as if they were 8 coax cables for better understanding, each at a frequency of communication with the FCB tuner, totally independent.
It's like the EuroNews channel on Astra at 19E, with the 8 audio tracks, you select the one you want and communication is correct.
Fisicamente es un coax cable, pero es como si fueran 8 cables coaxiales para entendernos mejor, cada uno en una frecuencia de comunicacion con el sintonizador FCB, totalmente independiente.
Es como el canal EuroNews en Astra a 19E, con las 8 pistas de audio, seleccionas el que quieres y la comunicacion es correcta.
By the limitation with satellites, I'll take the DUO2, I see very "green".
Por la limitacion con los satelites, me quedo con el DUO2, lo veo muy "verde".
On post # 10
Sobre el post #10
Topic solved.
Tema solucionado.
