Weird NO SIGNAL issue from standby
Manikm909
Small'ish Dish Man
Kent, UK
Got an Edision 4K E2 STB - TUNER A = motorised sat, TUNER B = 28.2e.
if its in standby for a few hours, when i bring it out of standby - there is no signal \ no picture.
i have to reboot it for the signal to come back....happens on either tuner.
any ideas...its not the latest image i must say
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Does this problem happen when you start up with any transponder, or just with horizontal transponders?
(possibly inrush current protection)
Greetz,
A33
Manikm909
Small'ish Dish Man
Kent, UK
Greetz,
A33
it doesn't seem to matter.
what i have noticed is i dont actually need to restart GUI.
if i switch from a channel on 28.2e (appearing dead) to another sat on the other Tuner A picture and signal returns, and then if i switch back to Tuner B on 28.2e - its fine also.
very odd
i will try reflashing however, it is ringing bells of a distant past when i had the same issue...
Power saving/screen saver setting in E2 menus configuration?
Manikm909
Small'ish Dish Man
Kent, UK
Manikm909
Small'ish Dish Man
Kent, UK
i switched to OPENATV as a test, and its been fine
must be my old VIX image giving me jip
OpenATV is a powerful image but I prefer the "Simple Ten Eighty" skin in OpenViX.
Other than that OpenATV is good.
Manikm909
Small'ish Dish Man
Kent, UK
so, as i can't stand OPENATV - mainly the file manager, i thought i'd try PURE2 - a great image indeed.
however, im getting the same NO SIGNAL error as i was with VIX image.
does anyone know if there is something fundamentally different with OPENATV IMAGES (no issue with the signal thing) - to the ones such as OPENVIX and PURE2 ? different kernal \ core etc...?
im now running a DEBUG LOG and will check in the morning....
Do you have a second - different brand - receiver to run each image as a comparison ? I'm wondering if the tuner drifts when in standby, and falls outside the capture frequency once on.
Otherwise see if offsetting the LNB Lo by 1MHz either way.
Manikm909
Small'ish Dish Man
Kent, UK
i played around with OPENATV again, and they have a SKIN available called the DEFAULT skin, which is quoite ironic, as its not the default skin the image comes with - and this puts the box into almost a VIX looking image. even the file manager looks ok - very happy with it now
Did playing with it widen your 'aperture' ?
