What Actuator for Channel Master 180 cm offset dish?
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Hallo, what motor is ok for Channel Master 180 cm offset dish? 3624 or 3624. What are practical differences? Thank you.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
They both will work exactly the same. But, if you meant one is heavy duty and another one not, then, as well, you can use any of them.
dishdx
www.dxing.cz
Central Bohemia
Thank you Rima, I know that it depends on polarmount construction, I want rotate ca 30W - 78,5E, so both would be ok? Polarmount I don´t have yet, but want to make one, construct by myself and I have found bulgarian actuators Sky Sat QARL 3624 and 3636 for acceptable price.
Manikm909
Small'ish Dish Man
Kent, UK
maybe you havent yet realised you put the same model in your OP
anyway - i went through this - the answer is, get a 36inch - but you need a way to offset the angle, or it fouls against the structure
see my thread here:
pic:
when i had the 24" i wanted to go from 54e to 58w - it couldnt
36" does the job, as long as u have an angled triangular plate as per my pic
RimaNTSS
N-E from Riga
For such a small arc any actuator will be OK. I had 1.8m dish on polar-mount with 24" actuator and it was easily turned 93*E-30*W. As it is said by @Manikm909 it is important to find the proper actuator connection points to prevent dish-flop or other damage.
Without knowing the o/p dish location in respect to high winds, it would always be worth adding bracketry to the existing polarmount for the longer actuator, to remove the chance of losing the lot in a bad storm.
But the original question was over which 24" actuator....
Manikm909
Small'ish Dish Man
Kent, UK
it wasnt he put the same model in twice....3624 or 3624
let me think, the 3624 ....? hmmmm
dishdx
www.dxing.cz
Central Bohemia
Sorry, of course I meant 3624 or 3636 :-) Sorry, for that!
dishdx
www.dxing.cz
Central Bohemia
