[updated:LAST EDITED ON 04-09-01 AT 07:50 AM (GMT)]O.K. for Funcard 3in1 to work on 9600 you need to have DVB1821dream its a version from November 2000. That is the only version of Firmware I have seen work consistently with Funcard3in1. The big difference that I can see is that when this version of DVB2000 accesses a channel, it will put on the screen which encryption type is being used, so you will actually see "S***" on the channel bar of a S*** channel or you will see "Vi****" on a Via channel as opposed to just the letter "S" which indicates that it is a scrambled channel. The Freecam settings made no difference regardless of provider. Make sure All-ECM is on, ECM is set to Ird*** and EMU is set to OFF.
The Freecam can be version .16 or .17. Palcos and Vi*** TV3's will not work and with some versions of Fun3in1, none of Vi**** on 5E will work, so try different versions. Funcard 3in1 v2.3 seems to be the most reliable. Also, the settings file from rehtec.com worked fine for the channels as well as the one from drhans.org.
If anyone is able to get Viasat Nordic to work with Fun3in1 and the 9600 or able to get DS9 to work with 9600, please post here how you did it. Also, if you have seen the combinations above work with other versions of DVB2000 with good results, give us a post !
