Which is your preferred Viewer for PC satellite TV
FraserGJ
35cm portable dish and Comag Porty II FTA Reciever (Lidl kit), Nokia 9850T DTT box.
Athlon 2600+, 512Mb RAM PC with Nebula DTT Card
South Wales, UK
I primarily use ProgDVB for watching standard broadcasts from various sats
I've also voted for DVBViewer because it lets me watch HD broadcasts as well and SD ones. ProgDVB seems not to be able to handle all the HD data or it introducing some interference because the HD picture breaks up - very annoying
I'm using a Skystar 2 PCI card :)
pothead13
Technomate 1500ci + 1000d super +
skystar 2 pci card
1M Motorised dish
Ivacon twin lnb
pc + laptop on network
uk
what chanels are the hd ones
mad_alfred
p4 3.2ghz
512mb ram
120 + 60gb hd
skystar 2
dual lnb 80cm dish
progDVB, fast and easy to use, why bother with all the others?!
grigsound
SkyStar2 dvb
P4 3ghz, 6800gt, audigy2 zs
progdvb definitely
kalamar
I now only use progDVB and s2emu,its the winner of them all,including the commercial pay programs. I have exaustively tested all of them and thats what my conclusions are based on.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
I find progdvb the best for most things. For HDTV I use HDTV demo which is the only smooth running program that works with the Skystar 1. Ritz DVD is unstable in its current version after channel scans and refuses to launch without a reinstall. It does work on HDTV. DVBDream has great potential for general use.
Artist 2004
Anatolia correspondent
GoldMaster 7400 CIM 2MB with Kaon board 12.03.a5. Technomate 1000, Technomate 5200 USB.
Two 80cm offset dishes.
West coast, Turkey
T_G said:
You can pick more than one option if you like a couple of viewers equally, if yours isn't there, then post here before voting and it will be included.
Just for interest's sake I have a different way to watch satellite TV on my PC. My Goldmaster receiver has a @SKY module lurking inside and some software to run on the PC. I connect them together with a USB cable and I can watch TV, record to HD, and make fancy channel and favourites menus on the PC.
DVB-slut
Fortec Star Dynamic Decoder
90cm Dish
USALS Motor
SkyStar2 PCI
PROG DVB
DVB VIEWER
California
Is there a driver for Prog DVB that will support a TechniSat SkyStar-USB box? If so can some one point me in the right direction on where I can find it? I have DVB Viewer but I understand that Prog DVB is better..
longjohn
PC+Siemens DVBsCard Rev1.5+ Multidec9.0\
dbox2+Neutrino\
Ferguson AF-3018SE\
Digital 800\
Palcom DSL-4\
Germany (but PT)
Multidec 9.0 its OK, with S2emu1.19 on w98.
Its run stable on a P200 and its easy to configure.
Have fun
:-Cbigsmil
longJohn
v759
v759
U.A.E
Mytheatre is very good with me. Doing great.
gojet
ITGATE TGS100 ..GOLDEN INTERSTAR 8005s ....powersky 8210..TechniSat "SkyStar 2 pci card..1.2 mrt dish & motor ...2 fixed dish astra ..hotbird...
uk
well i tride just about all of thr programs .and i still gome back to progdvb.always find nice and easy to set up and gives good pic q ..so progdvb gets my vote
ViReN
Box-»SrarTrack
World in Box(S170EC)
Soft-»(STM_A6690)
Sat's-»13.0E,26.0E,95.0E,105.5E
_Ξ-Middle East-Ξ_ -»Oman
Just to bump....
and have a question.. which ones are the ones that can be used with USB Reciever?
and which ones have patched wares / emu's ?
are these softwares generic over USB/PCI interfaces
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
for HD i vote for dvbdream 1.1h
although poll won't let me have another go
Bollux
PCTV SAT CI,PCTV 400i,PCTV Dual Sat Pro,Athlon XP 3200,1GB Memory,LG 4163B Burner,Artec DVD Rom,Seagate 160GB Hard drive,250 GB USB Hard drive
Germany
Hi ,
Just wanted to vote again but I can`T? Anyway I have 3 cards. The PCTV Sat Ci works best with ProgDVB, PCTV 400i works great with DvbDream, and at the moment I`m trying to get the PCTV Dual Sat Pro to run with ProgDVB,without much success!
rana143
setelite
Pakistan
What is the name and model of your mother board ? maybe I have some info on it.
who knows if our 32 bit DVB apps will run on a 64 bit OS?
goldie18
progdvb
united states
yes can you guys help me with this stuff im new to it and i need so help so im looking for all the stuff im gonna need to run my Hauppauge WinTV-GO TV Tuner Capture Card in my computer i have a abit 1.6gz proccesser 256mb video card and i just wanted to see if someone hear can help me figer this out thanks
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
INDIA
You are talking about which stuffs , Hardwares or Softwares, for extra attachment, You have many kind of softwares which support to run your card, and even hardwares which are even helpful.
Jontydog
Macclesfield
jonty.lb3.co.uk
Core2 Duo 3.40ghz 4 Gig Ram Skystar 2 PCI Card F3
Cheshire
I have gone for the newest version of Altdvb. A big improvement over progdvb it runs faster and uses less processing power.
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
INDIA
Yes you are right , The core is the diffrence, But MT AND DD are the professionals.
