frunko
- Oct 13, 2004
- Age
- 52
- Sky HD, Humax HD Freesat, DM500HD, 90cm dish with technomate motor.
- Highlands, Scotland
Hi All,
I'm sure this has been covered before, but I was looking online at the Smart-Wi system, which I believe doesn't support NDS.
Then noticed a system on mennyfix, it looks identical to the Smart-Wi, but it's described as 'NDS - Coming soon'.
Anyone know if this is for real? Or is it just bullsh*t to make people buy the product?
This is how it was described:
[SIZE=\"4\"]The Brand new Wireless Card Splitter[/SIZE]
Wireless Card Splitter is an Seca Mediaguard 1 & 2, Viaccess 1 & 2, Irdeto and Conax splitting hub. (Coming soon NDS) With this wireless card splitter you can share one original smart card between all your receivers(up to 7 receivers at the same time) and the card splitter will connect to the digital receivers by the wireless slave which will be insert in the receivers cam (embedded cam) and its work as the original card in your receiver. This solution is useful when you have more than 1 receiver in your home but you don’t want to pay monthly fee for extra card.
