Zenega CD1004iS Boot problem
Amandeep
DISH TV Zenega CD1004is
Bangalore
Thanks to this forum i was able to get my Dishtv STB fixed in less than Rs. 100.
Guys blinking red means your STB capacitors have gone bad, so please go ahead an replace them. I did replace both of the capacitors on my STB and my Dishtv is working as brand new.
About DISHTV they are chors and they have no ethics at all. The cheat their customers for everything.
Once again appreciate Abhigg for sharing the knowledege on this issue and helping us find the best way to fix this problem.
venki1234
zenega cd1004iS user with dishtv
Bangalore
After wasting the whole of today trying to get this problem fixed through dishtv service (which
is non-existent, if you actually try), I stumbled upon this thread. I've had the same problem repeat
once every six months or so and I've struggled with the dishtv service every single time.
I'll try replacing the two 25V, 1000uF, 105 deg C tomorrow and see how it goes (I don't see
anything marked V9 or V9A as someone mentioned in this thread earlier; hopefully that's fine).
ravi.baba.zaa
Zee DishTV
Pune, India
Problem with Zenega CD1004iS.
My box is ill.
It is not saving the info.
It ask for recharge or ask for card but both the things are in place.
Some time it keeps updating. What must be the issue. Any one can help me.
vladislav vaz
dish tv zanega cd1004s
goa
needed your urgent reply.. my dish tv set top box too got corrupted its showing orange light. mine is zanega cd-10046.. i read your post where you suggested to change the capacitor ..
im not sure which cap you tlking abt so ill try and describe it.. tell me if its correct..
its written as: 47uF 500v 85 degree C8 v3A which cap should i use instead of this? reply fast plz
The previous reply to your is from 2 years ago, and most of the contributors on this thread havent been active on the forum in a very long time.
But you need to use a cap thats rated equally or higher than the one you need to replace.
Also, we're a Hobby Forum, not an Emergency Service.
svprasad
kerala
i have an old zenega wich green light appears no video on tv
is that the capcitor problem .i want to use it for fta
