Fisty McB
- Aug 11, 2012
- See my signature...
- County Tyrone, N. Ireland
I'm a bit late replying to this, but the Astra 1, 2 and 3 series satellites all have an offset in their transmission skew, it's approximately 8 degrees clockwise IIRC. For the Astra 2 satellites in the UK & Ireland, this makes it have a skew value that would otherwise me more reminiscent of a point between the Astra 1 and Hot Bird satellites. For example, where I live a satellite TX at 28.2 East with zero offset would have a RX skew of -22.4 degrees - however the Astra 2 birds offset this to being -15 degrees. At 19.2 East the RX skew is -10 degrees, however at 13 East, since Eutelsat satellites have zero offset, the skew where I am is -13.9 degrees.I'm no expert on feed horns but I'd have thought the further away from 28e you get, the worse a Sky LNB with oval feed horn will perform due to the skew.
Therefore in my case, the difference in skew angle between reception from 28 East and 13 East is just over 1 degree - and using a Zone 1 or 2 dish with corresponding LNB the signal difference from adjusting the skew when moving the dish from one satellite position to another would be so tiny as to be unnoticeable. A small adjustment of the skew on the same dish would also be adequate for fine-tuning reception from 19 East.
