DIY Horizon to Horizon Polar Mount
blademedia
Sky
Perfect, I can weld this up now, part that carries the motor need cutting to size,
another possible issue that I am aware of the vertical parts should have been made from 50mm, ive taken a gamble that I wont be able to see the arc before it hits the vertical,
If I can see further I will V it out to allow more travel
As you can now see I don't have a full 90 degree E/W, not that we can see that far, it might restrict me on the W side for data transponders, if it is a problem I will cut into the verticals to allow more travel
IMG_3010.JPG IMG_3011.JPG IMG_3013.JPG IMG_3018.JPG IMG_3020.JPG IMG_3023.JPG IMG_3024.JPG IMG_3025.JPG
blademedia
Sky
Surely, that thing is able to carry larger dishes than the 2.4...
Thanks st1. yes could go a fair bit bigger than 2.4 its well on top of the job, but will stick with this, the oilite bushes are very smooth pleased with them,
Need to work out balance for drilling the pivot the chain ring makes a good counter balance, want everything nice and smooth.
blademedia
Sky
Welding nearly finished, cutting through angle grinder cable slowed me down:eek:, had to buy a new one. will repair other and keep it as spare
blademedia
Sky
I know the feeling, but I usually do that with the hedgetrimmer - lot's of waving the sword about...
Was lucky, didn't realise I had done it, lucky I didn't put my hand on the wire, it went bang when I picked it up
Drilled through 3 hidden (behind plaster or/and wall tiles) cables - with "interesting "results! Then, a couple of years ago, when the current cooker was being installed by the Currys delivery/installation teams, one of them got a shock when the cooker touched a wall hook in the confined space in front of it!, Turned out that I had screwed the hook into the wall just a mm or less away from the cable of the cable for the cooker that I installed decades ago - and the very slight impact of the cooker front on the hook drove it into the cable. "Shocking":(
blademedia
Sky
Have some spare time today, been in workshop and made this, just needs welding on, would like to get dish up before Christmas, best get cracked on.
blademedia
Sky
Perfect, thinking ahead pays off, the gearbox motor needs turning so the drain holes are in the correct place , also keeping the weight in the correct position at the rear of the mount not offset , something they haven't done on the one I am copying,
8 small holes to drill and one big one for the gear shaft, will do the big one first as it might need elongating so the chain falls correctly on the sprockets, then it can be bolted in place will use the holes top and bottom in the last picture for fixing it :)
blademedia
Sky
^^^ more luck than judgment :), it falls spot on, need to cut chain to size, shaft to length have a key slot machined into shaft, drill and bolt up.
blademedia
Sky
Picked a few parts up for this today, bolts and key for sprocket, have some spare time over the holiday :)
blademedia
Sky
Bolted motor on today
Then gave it a quick test, I need to do a few tweaks, so far looking good,
Small video
MVI 3187
That is going to be very precise positioning, good job.
blademedia
Sky
Awesome work!
Thanks, yes the small steps are very small even on a cheap positioner, the rc 2000 will really come into its own on the weak signals, no play in anything I put all me weight on it and no backlash and moved me no problem,
I estimate 4 mins 70 e/w, will pull the stops out of motor and check later in the week,
Time will tell if the motor will pull the dish from the extreme's of the arc, that's the only thing that might let the build down, I've already located bigger stronger motors just in case ones needed :), will be making the mount perfectly balanced pointing south to make it as smooth as possible,
I really need to get on with the base tbh mount no good with out it
Another small video I did yesterday
MVI 3185
sat1978
Tbs6522 ns2000
Asia
Wow great job!
blademedia,
You put in a lot of work and time to build this chain driven polar mount and it looks to be very high quality. Have you plans for it now you have installed the 2.4m DH antenna? I hope the chain drive mount gets put into service as it is a top class piece of fabrication and whoever uses it will get many years use out of it.
Rgds
