blademedia
- Jul 29, 2016
- Sky
- UK
Perfect, I can weld this up now, part that carries the motor need cutting to size,
As you can now see I don't have a full 90 degree E/W, not that we can see that far, it might restrict me on the W side for data transponders, if it is a problem I will cut into the verticals to allow more travel
another possible issue that I am aware of the vertical parts should have been made from 50mm, ive taken a gamble that I wont be able to see the arc before it hits the vertical,
If I can see further I will V it out to allow more travel
