Eutelsat 8WB (8W / 8.1W) C-Band Active
Thanks for confirming the position :)
Your on a mission Chris lol, sorry i can't help out at the moment as mine is chained down at the moment due to wind gusts etc.
Archive-8
Just for fun I strapped my wsi C&Ku combo on the dish.
Never had the cband lnb in prime position before.
Still need to find a few more positions.
Sadly 40.5°W is a no go with the dish in its current position.
pride21
Sandown Isle of Wight
hi all i managed to get Asonga at last been a trying time to get it.P2050019.jpg
pride21
hi once again here is the new plate which got Asonga i tried all different plates they would not pick it up,i have the dimensions on the photo if anyone wants to make one,all the copper bits are stuck to double sided carpet tape.P2050020.jpg
hi once again here is the new plate which got Asonga i tried all different plates they would not pick it up,i have the dimensions on the photo if anyone wants to make one,all the copper bits are stuck to double sided carpet tape.View attachment 114489
Nice one Squire, that's worth having a go at and then evaluating against the AV-Comm barrel. Any chance of re-photographing the drawing to a bigger file to make it a bit more readable and some actual pics of the device would be great . Yeah, fancy a go with this .
Cheers.
Edit: Is that off the 1.5 Gibby ?.
pride21
hi john yes thats off 1.5cm gibby,i will have ago at another photo and try and blow it up bigger.
Pride, is that a piece of perspex the pins are stuck to?
pride21
hi scopus yes it is its 1mm thickness.
