blademedia
- Sky
- UK
I am more used to working on things under a microscope than this. I have ordered various cutting and grinding tools as suggested by BM & MB as most of my tools are meant for sub-mm work.
Things will change when you start the 3.8 install s-b, you need strong back, just picked up levelling system for my build each section weighs 150lb
it will be fixed to construction on wheels square box section bolted to it with round adaptor bolted to box section for dish mount
