Intelsat 904 at 45° E (relocation)
adonis1
Intelsat 904 planned for relocation to 45E orbital position where it is planned to replace Intelsat 12 that is expected to be deorbited at the end of 2017
I-904 is only 2 years younger than I-12, so must be a temporary assignment until Azerspace 2 goes into service
Current Intelsat 904 footprints @ 60 east
FlySat Intelsat 904 @ 60° East Beams
Possible C band activity from 45 east ?
Intelsat 12 current European footprint below:-
Southern Spain & Portugal will loose 45 east with a 100cm dish on the change over to Intelsat 904.
adonis1
Intelsat 38 (Azerspace-2) has been scheduled for launching at the end of 2017 (or beginning of 2018)
Intelsat-904 is probably at 45 east now to replace Intelsat 12 (incl. 0.2°) 45.0°E
INTELSAT 904
NORAD ID:
27380
LOCAL TIME:
09:14:34
UTC:
09:14:34
LATITUDE:
-0.05
LONGITUDE:
43.55
ALTITUDE [km]:
35834.76
ALTITUDE [mi]:
22266.69
SPEED [km/s]:
3.07
SPEED [mi/s]:
1.91
AZIMUTH: 129.7 SE
ELEVATION:
+18.5
RIGHT ASCENSION:
00h 20m 01s
DECLINATION:
-08° 21' 01''
Local Sidereal Time:
21h 11m 26s
The satellite is in day light
SATELLITE PERIOD:
1439m
TLE will be corrected soon currently running on auto predicted so not the actual position Real time satellite tracking for: INTELSAT 904
Active part of the Ku band for Intelsat 904 as mentioned in post #1
10950 to 11700 H & V,
As AzerSpace 1@ 46° East uses 10950 to 11200 so expect new transponders in the 11200 to 11700 part of the Ku band a frequency share plan may be used.
Laser
Anyone know if Prima TV and Kiss TV have moved to Intelsat 904 on 12560V 5787 ? Flysat says not moved. Signal not as good as it was. Intelsat 12 is inclined though...
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Still good signals here from 12560 V 5787 Prima & Kiss on Intelsat 12 (incl. 0.4°) with a 88cm dish 97% Signal Quality.
Laser
Signal yesterday was down to 85%Signal quality. Back now to 97% Signal Quality. Would these variations be down to the satellite being slightly inclined?
Yes, likely. Yesterday evening when you reported bad quality, IS-12 was more than 0.3° above the belt, and now below.
This may also indicate your dish is pointing a tad too low.
popovp
Varna, Bulgaria
Yes, software bug - the previous selected channel.
mister_rf
Redline TS3000HD
motorized 120 antenna
fixed dish 150
Invacom LNB
Bucharest, Romania
Yesterday, 14th June 2017, Prima Tv and Kiss TV channels has ceased transmission on Intelsat IS12.
Intelsat filed its annual Form 20-F yesterday (an annual report over 2017), including the estimated end of service life of their satellites.
There are changes for the three satellites at 45°E:
Galaxy 11 and Intelsat 904 should last until Q4 2018.
The inclined Intelsat 12 should last until Q3 2019. Remarkable, because in the 2016 report it was until Q4 2017.
Intelsat 12 (incl. 1.7°) has left 45.1°E, and will arrive at 64.25°E in March.
So now at 45°E, we still have Intelsat 904 (incl. 0.3°) at 45.1°E, and Galaxy 11 at 44.9°E.
