I had a Rover meter some time back, fiddly little screen, not very responsive, I didn't like it personally.What's a good pro satellite meters you recommend?
Have seen a rover st2 second hand wondering if any good?
I'm not a satellite installer, I'm an electrical contractor ,
but use a Promax HD Ranger+ for my hobby use and love it.
There is a ST2 and a master stc for sale what's the difference?The Rover ST range can be a tad slow on spectrum trace. All really depends on budget and exact uses.
Not sure. I had the Master one, but sold it on.There is a ST2 and a master stc for sale what's the difference?
Is there like a guide on aligning a dish using a pro meter using all the featuresA spectrum trace is very useful for adjustment to LNB skew.
What do you think of the satfinder 5hd slim?A spectrum trace is very useful for adjustment to LNB skew.
Not a bad little meter is that. I use one, nice and compact for outside. Refresh rate in the spectrum is decent too.What do you think of the satfinder 5hd slim?
I usually use the spectrum first, then look at the levels..Do you find it more accurate to align with spectrum analyser, Constellation or individual channels dB level?
