AMIKO A4K Combo
AMIKO A4K Combo
I have been testing this receiver for a couple of weeks now,
4K DIGITAL SATELLITE & T2 TERRESTRIAL / CABLE RECEIVER & MEDIA PLAYER POWERED BY ANDROID
Compact Design
One S2 satellite & one T2 terrestrial / cable hybrid tuner
One card reader
Fast & easy installation
64bit Quad Core 2.0GHz processor
8GB integrated flash memory
2 USB2.0 connections
Micro SD card expansion slot
Google Play™
YouTube videos
Based on Android™
Hundreds of thousands of available applications!
KODI media player support
Easy streaming to iOS, Android™ devices & PC’s
DLNA - Easy playback over local network
4K 2160p output via HDMI2.0
Ethernet connection & built in Wireless-N WiFi
Wired and wireless keyboard & mouse support
High quality digital surround sound via S/PDIF & HDMI
Low power consumption in Stand-By mode
Blind Scan works well finds UHD,HD & SD transponders,
UHD pics to follow.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
AMIKO A4K Combo
Thanks for that 'william'....reads well.
¿Assume that is your attached pic so I guess that the receiver can cope with BISS/CW emulation?
Merry Christmas and hope you enjoy your weekend. :)
stephan94
Bavaria
Hallo williams-1
how is the blindscan of this receiver? speed etc...
Hallo williams-1
Astra @ 19.2 east 10700 to 12750 takes 10 min for the FTA Blind Scan to find all the active frequencies,
Then it takes 4 min to add the channels to the data base.
You can select V or H or All polarizations.
During the Blind Scan the found transponders go in sequence in the data base,
Next Blind Scan:- 10 east & 9 east
DSCN2216[1].JPG DSCN2218[1].JPG The Blind Scan is split into 4 bands currently unselectable by the user,
High Band H 11560 to 12750
High Band V 11550 to 12750
Low Band H 10700 to 11900
Low Band V 10700 to 11900
I also observed that they overlap o_O
stephan94
Bavaria
Thank you Williams-1 a lot for the answers.:-applause
another question:
until what little SR works the blindscan (for example the SX88 does not find in SR1600)?
the 3 ° 1 East satellite is the right satellite to check that.
how much MhZ is the minimum separation between two frequencies?
Good parties of New Year.
stephan94;)
I will check out the low symbol rate Blind scan on Eutelsat 3B & 21B.
Symbol rates as low as 1500 found with the A4K Blind Scan,
Active transponders found within 3 MHz range,
Screen shots to follow.
I have deleted all symbol rates below 1600 from the A4K data base for Eutelsat 3B @ 3.1 east before I start the Blind Scan test.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Hey William, should you not have waited till tomorrow before unpacking your Xmas pressie?
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
How much better is this compared to the Amiko A3 ? Shame no USB 3.0
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
I guess the tests did not go well as no news here!
The test was fine found all active transponders on 3.1 east.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Yes it is my preferred receiver for DTH TV,
I much prefer the TM5502HD for feed hunting with the inbuilt spectrum analyser I can find feeds much quicker as I can select what part of the Ku band I want to scan.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
What's Android like for Satellite stuff, is it easy enough to tune, add transponders, set up a motorised dish etc?
Looks quite interesting that box.
