7°E Eutelsat 7
Locks but no picture, absolutely piddling down here. Seen brief colour bars...P1010028.JPG P1010029.JPG
... I'll have a gander bruv ;)
Think i was too late to the party Chris, looks like it's gone now.
s-band
Essex
Playing with a Prodelin Ku feed + adapter on 1.2m offset, todays scan. The narrow cluster don't all show on blind scan but are OK once locked.
Thats actually pretty good going for the 7°East scan Graham, your in a favourable location down there as you are within the strongest part of the footprint, i'm lucky to catch 3 up here. The weather has now changed to cold rain so the Gilat test is looking a bit of a no-go at the minute.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Active now (again):
21665 H 9600 3/5 DVB-S2/HD 8PSK
... absolutely no sign of that here Edgar, can you see it Llew ?.
dx qwer
Rastatt/Germany
Sorry John, this feed has left right after my post here. Probably it will be on some minutes later?
dx qwer
Rastatt/Germany
On again now 21665 H.
Strong signal with me....
I can see the TP, but it's only 4.2dB, so no lock. My Triax is certain to be a victim of the gales, and will be off the sat.
I'll rectify it tomorrow, but probably too late for the feed. We'll see.
dx qwer
Rastatt/Germany
Active, TC now:
21717 H 7000 3/4 DVB-S2/HD 8PSK
PS: Reported yesterday already by John.
Laser
I have one of the Inverto Ka+Ku Lnbs. Thinking about fixing it up. Bought a while ago
However it shows 21.2-22.2 (LO 20.25 GHz)
Which satellite it that designed for please?
If anyone can help. Thanks.
Archive-8
7°E is the main channels.
Check 16°E & 5°E
Also what you could do - - You could put the Inverto Ka/Ku on the 1.2 CM, run an extra coax up to the dish, and you will have full Ku band and full Ka band D at your desposal. The Ku performance of the Inverto is pretty good to say the Inverto is a compromise lnbf but with some attention to detail as to setting the lnbf up on the dish you will be sound. I have a 1.2 CM as well doing exactly this.
Laser
Thanks John. Was thinking of doing exactly what you suggest.
Do you think the combined LNB Ku is not quite as good then as the single Inverto LNB?
Well, briefly imho, any lnb/lnbf - 'C' , Ku, Ka etc you use on a motorised dish that scans a good portion of the arc ends up as a bit of a compromise re: performance. A 'one fixed' lnb position at the front of the dish is not a 'fits all' situation to cover the arc. Tweeking an lnb/skew/focal point/choice of lnb+scalar feed used to optomise illumination etc on a fixed satellite position and on a fixed frequency gives you the opportunity to fine tune for max performance - SO using the Inverto Ka/Ku over various arc positions is not perfect but imo pretty darn good for what they cost.
dreamsat
germany
21750 H 17270 2/3 New Programms and new SR
regards dreamsat
Thanks dreamsat. TV13 ,TV14 and TV15 are the same broadcast (thumbnails showing delayed capture times of same channel).
dreamsat
germany
After program change, the performance of this transponder is the same as before.
regards dreamsat
