s-band
- 1.5m IRTE PF, Invacom SNF-031, TBS6983,
- Essex
Today's scan using 1.2m offset. Some narrow TPs had to be manually locked.
Pretty good and interesting, you have an extra one at 21536 1099ks/s but missed the one at 21541 1070ks/s (the upper one of the 2 1070ks/s, our freq cal is different). What's on 21536 (21534 Lyngsat listing)? Pouring here now and the electronics has been removed. Yesterday's scans were clear sky but there was ice on the dish late in the day. I think a physical filter is needed to separate some of these narrow, close spaced TPs, especially on 7E. Both Gilats (bands B & D) give a total system noise figure of 2-2.5dB (inc feed, dish etc) so could be better.It's not doing too bad Graham, here's my scan this morning looking through overcast / drizzle etc. Using Inverto Ka/Ku lnbf with Hughes scalar fitted, location North Notts.
Might be a bit too cold and wet to test the Gilat on the test dish today Graham lol.
Here's tonights scan using a Gilat feed on an unmodified LNB
I managed to lock the radio TPs using EBSPro
View attachment 113026View attachment 113027
I have to remove the electronics over night. It's there now but many signals are ~1dB down and the dish waving in the wind doesn't help. It takes a while to lock and sometimes a couple of tries. BTW, I think that Alpha Blondy FM is on 21548.0 not 21548.2 as per Lyngsat... If you can Graham, can you check if you can still resolve the radio station "Immaculee.Conception" .... 21.564 SR 128 @ 3/4. There's absolutely no sign of it here.
View attachment 113068View attachment 113069
Unusually for Crazyscan, Radio Immac at SR 127 was found during scanning, although I needed to enter the correct SR in the constellation box to lock it.
TBS 6983, XMW LNB, Triax 88.
What type of receiver /dish is needed to receive the 20 000+ frequencies?
Thank you very much for your answer...
i am in carcassonne near toulouse, not in the barcelona null
i get good signals from the 16°E Ku band,romania slovenia albania(the new albaniaHD weaker but very watchable)
But how do you use TBS 6903 / 6983 pc cards? is that a usb device you plug in... into the Crazyscan prog?
i m a bit lost/Would the Octagon receive such signals?
Haopy new year from Carcassonne Languedoc(now Occitania)
I've never seen it in a scan and, until now, nothing I could do would lock it using Crazyscan. Finally after about the 5th try, it locked:
