Retired human
- See signature
- North Somerset
A few things to try. Will let you know the results.
I can bring some ferrites over to test when I pop over if you want to experiment?A few things to try. Will let you know the results.
I have the exact same interference at the same frequencies. I have 2 feeds off the dish; one through a v box one not. The ok next through the v box has the interference. I switched off dect phones in the house but stiil had the problem. I changed thev box to a different make (not much choice out there these day) but still had the problem. Unfortunately, I suspect to the neighbor through the wall has a dect phone and I can't do anything about that. I even attempted to build a Faraday cage around the v box with no success. After that I ran out of ideas except for purchasing next door to rent witha non dect clause in the agreement!
