A Meter? Yes it is worth getting.
TJExcalibur
Out of this world.
Southern England
I was going through the channels of 19 East and realised there was no Pearl 4K, I like the cheeky girl on there. I had done this sat with positioner, tried auto focus but it always abandons and goes back to previous. Therefore I moved left and right for the strongest reading and save it in advanced settings. . On doing a manual scan no Pearl TV 4K. Plugged in the meter and tweaked it to west for the best reading. Another scan and Pearl 4K is there. It appears as if the E2 positioner is only a near enough.
I thought there were two cheeky girls ?
TJExcalibur
Out of this world.
Southern England
Manikm909
Small'ish Dish Man
Kent, UK
if you're using Enigma 2, you can use a mobile phone with Sat Finder App on same WIFI\LAN as the E2 STB, and fine \ tweak signal \ channel in real time.
no need for meters when using E2, and your WIFI is strong enough to reach you up a ladder.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
There is no need of any Android app for doing it.
The browser can show the signal finder of E2 ( every 3 or 5 seconds ).
A laptop can do the job too.
Manikm909
Small'ish Dish Man
Kent, UK
....IF you want to take a laptop on the roof, and if you want to wait 3-5 seconds per every adjustment you make
