Advice Needed What is best
Adam792
Cheltenham
Yes I've been playing around with this, if you edit the satellites.xml and other things the box just default them back to what they were.
I think what they are doing is emulating the E2 satellite config settings by using a cut down version of these files which are only for use with a compatible programme for cross compatibility, the box seems to copy these settings to another location. It doesn't actually use them directly.
Editing transponders does not work using FTP or E2 editing softwares, however E-Channelizer will connect to the box and upload/download, I recon that might stand a good chance of importing channels. I have a E2 box here and will quickly try and dump 27.5W from the Mutant and load it on to the Edision... Will report back shortly.
Sounds like you might be in with a chance there then! Hopefully it works!
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I've got the channels uploaded to the Edision, I need to find the rest of the config for these channels now to see if I can get them working...
Adam792
Cheltenham
Kingofsat is my go-to for the PIDs!
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Just a quick update, I've found what you can and can't change in Dreambox Edit.
Still working on it and will post back shortly.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I'm sure this is all correct, unless PIDS etc have changed?
I just can't get it to display a picture or sound...
I assume you have the correct BISS keys in place?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Staff Note
re. Keys ..... the rope is short <_<
Solicitation and Provision are not permitted, but we've generally exercised discretion over generalities. As long as it doesn't go too far, of course.
Hi all been a long time since I've been on the forum a lot of new names on here now!!
Need some advice on the best receiver for 11495 v 44100-9/10 lntelsat 907 27 w
Ease of use is important (l haven't got much better! !! ) aac codec
Any info and experience would be much appreciated
I think this topic and this one might also help to choose what you need for 11495 V.
Staff Note
Surely it’s still along the ‘hacking’ route though?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
This discussion is veering off the Topic.
Rest assured Staff monitor such discussions and will make a judgement as to whether things go too far.
Any concerns should be raised by using the Report facility or by contacting a Staff Member, and not by Posting on Forum.
In a couple of hours, I shall tidy up recent Posts in order to restore continuity.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Some of this might be better suited in the Edision thread, so may start a new one there with my progress.
TL;DR - Doesn't currently work with the Edision Primo IP S2/Octagon SX88
handyandy
Amiko Impulse, Edision Pico, Edision Primo IP
BBC 27.5W, Astra1 19.2
Portugal
Hi. I have had success with Dreambox edit and Primo but still no picture. The transponder scan, even showing good level and quality, does not find channels.PID.JPGPID2.JPG
Mickha
North West
Those channels are BISS encrypted, and require some extra work, to scan in and view, especially on Enigma 2 receivers.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
It still won't work on these boxes.
Mickha
North West
I know they can be made to work on VU+, and some other Enigma 2, receivers, but I think you have to edit, or replace, the lamedb file, and do a few other things.
I have no idea regarding an Edision receiver, but I see, by the posts, that RustySpoons seems to have tried everything.
I seem to recall the old Technomate receivers can handle them quite easily, without to much work, but I can't recall the specific models.
They used to be something to do with Halloween, but the last time I saw one was three years or so back.
