Terryl
- OpenBox X5 on a 1 meter motorized dish.
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
Yah that would do fine if thats all you can get, and that clip will work great, do a couple of wraps for the USB cable through it.
But the screen stuff should be aluminum, as the heat sink is aluminum, dis-similar metals can cause other problems.
