No "Reply" Options (Certain Browsers only)!!
chris
TalkTalk TV
Worksop UK
As I'm not able to reproduce the issue myself it's hard to fix it. Can anybody who is experiencing this problem register at xenforo.com to see if there site does the same please.
Tururu
Assembled with recycled parts
Recycled as the owner.
4wd
Getting the picture
5 W, 9-13-19-28 E
Here's a (gigantic) forum using xenforo. I must say I prefer their looks, layout and general navigation.
NotebookReview
But things are ok enough here, have got used to changes and small irritations, so not complaining :O)
chris
TalkTalk TV
Worksop UK
I've disabled some plugins can you confirm if this has sorted the issues?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
No idea chris but getting a security error message when loging out now
Interesting. I generally only log out when going on holiday, but have just done so without getting any untoward message or other ill effect.
Topper
Very strange, I have just logged out again and get a message asking me to accept cookies after loggin out, I am in the Middle East at the moment so perhaps ignore what I am saying
It hasn't altered the reply box problem for me.
Removing compatibility view also removed the reply box. I had to reinstate compatibility view to post this.
I don't normally log out as I keep tabs open but as an experiment I've just done so.
No problems logging back in. There was a banner asking me to accept cookies once I had logged out but I ignored that and once logged back in again it disappeared.
chris
TalkTalk TV
Worksop UK
Do you get the reply box problem at xenforo.com ?
Tururu
Now if it works, it gave problems to upload the photos, but fine and now ok, so perfect.
The post has to authorize a moderator.
Extra work for the moderators.
.. :-doh
Ahora si funciona, dio problemas para subir las fotos, pero bien y ahora ok, asi perfecto.
Los post los tiene que autorizar un moderador.
Curro extra para los moderadores
..:-rofl2
So do I. There appears to be less wasted white space between the topics. I have long railed against this and I am convinced this must surely be a setting alteration somewhere.
Also they manage to survive without the awful floating header
Now if it works, it gave problems to upload the photos, but good and aora ok, so perfect and you do not have to authorize my post a moderator. :-doh
Ahora si funciona, dio problemas para subir las fotos, pero bien y aora ok, asi perfecto y ya no tiene que autorizar mis post un moderador.:-rofl2
ALL non-Staff Posts in this section are subject to Approval: That's not a glitch, but a Policy! :D
Just logged out and in again in FF - apart from being requested to Accept Cookies, that seems to be Ok and I can use the Reply function.
Then tried IE11, again had to Accept Cookier before I logged in - but the Reply function is now operational again in that as well !
So, @chris , which plug-ins seem to be the guilty one(s)?
chris
TalkTalk TV
Worksop UK
Not sure they are all turned off at the moment so will need to turn them on one by one to find the culprit.
I registered at Xenforo and the reply box shows up properly with all the formatting controls present. Ctrl-I, B and U work as they're supposed to. This is without invoking compatibility view.
Alt-S doesn't work however which seems to show that Xenforo have either forgotten it or deliberately stopped it. Either way it's damned nuisance.
