OCTAGON SF8008 E2 4K UHD
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
I think it's the same box: ANADOL ECO 4K
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
There are some similarities with ANADOL ECO 4K but the OCTAGON SF8008 E2 4K UHD is a combo receiver & has a Blind Scan the Anadol Eco 4K does not have either of these features the rear panel is the same on both receivers so probably out of the same factory.
Anadol ECO 4K UHD E2 Linux Sat Receiver
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Although this is not a Combo box, it may very well have Blind Scan, there is a OpenATV Image for it.
It might be worth checking their forums or I might even e-mail Anadol.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Just spoke to Anadol, in German.
Basically they said it doesn't have blindscan at the moment but may come later.
I wonder if the Octagon actually has it on release?
cardiff
Brittany
France
there are recent pictures of blindscan on Turksat 42 E (on Octagon SF8008)
Well if it hasn't got blind scan on release I for one will not be buying it!
huve
Faval SH 100, Mystique SaTiX-S2 Sky V2 USB, GI 110 cm, Inverto Black Ultra single
Helsinki
That Anadol box might have different tuner and demod than 8008. 8008 has same tuner and demod as 4008. On the german dxtv.de forum Octagon says 8008 has blind scan and there are pictures. Octagon says that 4008 and 8008 has different manufactures and driver engineers. The other driver engineer knows how to make a blind scan, the other does not (and has been trying a year and a half). Somebody on the forum asked after that, do we have to forget blind scan on 4008. Octagon says there is still hope on 4008.
The Blind Scan looks promising on the OCTAGON SF8008 E2 4K UHD,
With start frequency & stop frequency + polarisation selection & symbol rate selection :)
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
+1
If the new SF8008 has options to scan a user defined frequency range and polarity band it is worthy of consideration.
Open ATV, have always had a user defined BS, so it looks promising for the 8008
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
All images have that nowadays surely? Just tried it on my Gigablue 4k running vix, and it don't work, just get the 'no transponders found'. Doing the 'full range' scan finds most transponders.
So if you are expecting it to rival other boxes blindscan, wait until it is confirmed, because I seriously doubt it.
I remember it worked on my Solo2 using vix, but missed more transponders than it found.
Good advice.
I have yet to find an E2 box that has a blind scan that can remotely compete with a Dr HD F15 or a Technomate TM-5402. A good test for this new Octagon jobbie would to compare its blind scan result with that from a TBS card such as a 6903 or 6983 where the blind scans are done on a like for like basis (possibly excluding 16APSK and 32APSK detection from the TBS card).
Just my humble guess but I think the TBS card would kick the sh*t out of the Octagon .
Yes Dave I think all E2 images that have working blindscan have parameter control.
I'm not expecting it to be all and end all of blindscan, my other boxes take care of that perfectly.
I have experienced the Open ATV blind scan on the Azboz ME in the past, it was OK certainly the best of all the images I tried. A wait and see I think...
MCelliotG
Thessaloniki, Greece
Guys this is a very GENERIC blindscan function screen, based on the blindscan plugin, modified to be integrated into the OpenATV system. It utilizes external binaries on some blindscan-capable tuners, provided these are present in the firmware either directly from the tuner manufacturers, either from the receiver manufacturers and in that case they are closed sourced and encrypted to work on that receiver only!
Even though the scan results, especially with Silicon tuners are quite satisfactory, this approach is based on incomplete coding. Proper blindscan is a function that has to be built in the Scan Setup screens as a search type. For Silicon tuners only DMM has this implemented correctly and of course they keep this coding as a well kept precious secret.
Honestly, all manufacturers that use Silicon Labs tuners are to blame here. They are totally responsible for not activating blindscan on their boxes. In Octagon's case it's even more blatantly apparent that they use the Blindscan feature to promote their new receiver's sales, although SF4008 is more than capable of hardware blindscanning!
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
What is supposed to be so special about DMM blindscan?
Are Scan setup screens are python files in Open ATV images for DMM boxes? There is a blindscan binary in usr/bin, and a blindscan plugin for a user interface. This is the same setup other enigma2 receivers have. No one that has DMM receivers here in the States has reported a better or worse blindscan when using DMM receivers.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
I'm curious after reading the above.
I get nothing when trying blind scan on my TM Nano M3 with Open Vix. Can I assume I never will?
MCelliotG
DMM blindscan reports all found frequencies first, whether the results are better or worse I can't confirm, since I don't own a Dreambox.
