Advice Needed Receivers with the lowest Symbol Rate?
Oh well, if you wanna get that technical, indeed RT270 is the tuner, the user sees Si2166D as the tuner description.
Can you check if it is a Silicon Labs device ?
The last time I saw an all in one DVBS(2) tuner/demodulator it was made by Philips (and that was a while ago)
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
That's some stuff I'm experimenting with, I have a MiniTiouner here but curious to how low a DVB-S/S2 receiver can go :)
Theoretically to the point where nothing useful is received on screen.
stonesatellite
Vu+ Duo 4K SE (2x DVB-S2X) (2x Xbox One USB tuners (1x DVB-C & 1x DVB-T2) (1x Nooelec NESDR Nano 2+ USB RTL-SDR tuner)
Octagon SF8008 (2x DVB-S2X)
Mut@nt HD51 (2x 2x DVB-S2X)
Triax TD110
Sky zone 1 minidish
Inverto Black Ultra Twin LNB
Alsat Superior Dark Motor
Onkyo TX-SR605
6x Bose Acoustimass/Lifestyle double speakers
Stone, Staffordshire
Does anyone know if there are any receivers that can do Symbol rates in kS/s ranges below 1000,
I know that some PCI cards can do it, but are there any receivers that are able to go really low in the 100's range?
my Mut@nt HD51 will do low symbol rates like this one here Search Results for - KingOfSat
EnoSat
enosat.euweb.cz
Slovakia
Mutant HD51 - SR-285 work , but not show SNR
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
MCelliotG
Thessaloniki, Greece
I'm actually glad cause it shows the power of the Silabs tuner, however I would be really complete if the driver they issued had the full potential of it, like real time readings, and above all blindscan!
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
the Dreambox with the same tuner has blindscan, why Mut@nt didnt implement it is beyond me
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
No tuner finds all low symbol rates on auto search. Also at the card dvbs you have to search them manually.
aye i noticed the other day some low symbol rate radio stations were missing from my channel list, so manually scanned in the missing ones & there they are
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Octagon 8008 blindsacanned and plays 11675V on 23.5 with SR 874. Quite good. Octagon SX88 goes "only" around with blindscan 1600.
Are there currently any sub 1000 s/r channels on Hispasat ? I've borrowed a couple of receivers from a customer but will have to give them back tomorrow
Tururu
Assembled with recycled parts
Recycled as the owner.
Thank you, but they are 10000 s/r, I'm looking for transponders to test the receivers tuner lower limits.
dishdx
www.dxing.cz
Central Bohemia
My scan in EBS from 23.1.2019 shows on Hispasat 30W:
12520 H 2/3 SR 719
11485 H 7/8 SR 768
