Fat 32 or ntfs to record on my comag fta sat receiver?which is more convenient?
rodscha
I discovered by chance I could format my hard drive in Fat 32 OR ntfs..
How do they compare in quality,space occupied?
If I want to record on USB is ntfs any better?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Not 100% sure however I thought most STB's only use FAT 32 however, if the STB format menu option allows you to format using both, this suggests it can use both
rodscha
I wondered basically if,in daily usage of the hard drive for everyday recordings,
using NTFS would require more space for recordings(or less)
Also ,will files be easier to handle ,or of a better quality, under FAT32 or NTFS ,or is that indifferent?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
It won't affect the file size or anything like that.
Fat32 file size limit is around 1gb so if it recoded using NTFS then it won't split it into sequencial files like Fat32 would.
rodscha
thank you very much for the quick answer! ,so it seems there aee no big differences between the 2 formats
The biggest difference is that FAT32 is an open format whilst NTFS is a proprietary Microsoft format.
Topper
FAT32 is limited to 4Gb file sizes and ntfs is not
