10758v signal drop
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
Hi all,
As I can not get reception of ITV HD I manage with the SD versions.
I have always used 10758V for Itv1,2,4 and 10906V for Itv3, always with same signal in both frequences but I have just realiced that from 2 weeks ago more or less I have less signal in 10758V
Someone has experienced this new situation?
Nalleman
Motala Sweden
Sweden
I'm in Sweden so quite far off from you but here there are no changes in signal levels.
Acctually the signal has improved on usually weak transponders such as 11 023 H and 11 053 H but they are on 2G and the two you mention on 2E.
It could be something in the feed, or issue with the LNB itself affecting the lowest frequencies received from space.
S
Sleepingwiththefish
Over here 10758V looks the same as before, tops at around 12.7dB
I get ITV HD from 11068V, ~10.7dB because I have better signal compared to 11053H, 11097V
superpascu2
Alicante
I will check the dish, must be something wrong.
superpascu2
Alicante
I have just fixed the dish, an slightly movement upwards and I have gained what I had lost (winds, water...) Apart from that May and June are the ones with lower signal in my area (I can't lock BBC HD for most of the day)
S
Sleepingwiththefish
You could try to find a cheap bigger dish locally, it would possibly work nicely...
It is also a great enjoyment restoring an old dish to working order and installing it .:D
I 'found' one the other day... for free, I just need to collect it, around 1.8m (need exact measures) prime focus missing LNB holder, but reflector still pretty good after +30 years.
superpascu2
Alicante
No posible for me, I dont have room for something bigger but I am happy with what I have,.
Thanks anyway
