Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
Uhhh... there are no such frequencies on 80e.
Edit: looks like Lyngsat is out of date... To answer your question, read from the start of this thread :)
list is updated on flysat 80e two tp is T2-MI 11151 and 11187 both V and same symbol rate 14990 i stuck on this
Jan 01 05:46:52: INFO: SUB: type: teletext
Jan 01 05:46:52: INFO: SUB: page: 100 (initial page), language: rus
Jan 01 05:46:52: INFO: DATA: pid: 1045 type: User private (0x86)
Jan 01 05:46:52: INFO: PMT: crc32: 0xA7DC27A9
Jan 01 05:46:52: INFO: SDT: tsid: 1
Jan 01 05:46:52: INFO: SDT: sid: 1010
Jan 01 05:46:52: INFO: SDT: Service: 01 ПЕРВЫЙ КАНАЛ
Jan 01 05:46:52: INFO: SDT: Provider: РТРС
Jan 01 05:46:52: INFO: SDT: sid: 1030
Jan 01 05:46:52: INFO: SDT: Service: 03 МАТЧ!
Jan 01 05:46:52: INFO: SDT: sid: 1040
Jan 01 05:46:52: INFO: SDT: Service: 04 НТВ
Jan 01 05:46:52: INFO: SDT: sid: 1050
Jan 01 05:46:52: INFO: SDT: Service: 05 ПЯТЫЙ КАНАЛ
Jan 01 05:46:52: INFO: SDT: sid: 1060
Jan 01 05:46:52: INFO: SDT: Service: 06 РОССИЯ-К
Jan 01 05:46:52: INFO: SDT: sid: 1080
Jan 01 05:46:52: INFO: SDT: Service: 08 КАРУСЕЛЬ
Jan 01 05:46:52: INFO: SDT: sid: 1090
Jan 01 05:46:52: INFO: SDT: Service: 09 ОТР
Jan 01 05:46:52: INFO: SDT: sid: 1100
Jan 01 05:46:52: INFO: SDT: Service: 10 ТВ Центр
Jan 01 05:46:52: INFO: SDT: sid: 1110
Jan 01 05:46:52: INFO: SDT: Service: ВЕСТИ ФМ
Jan 01 05:46:52: INFO: SDT: sid: 1120
Jan 01 05:46:52: INFO: SDT: Service: МАЯК
Jan 01 05:46:52: INFO: SDT: crc32: 0x731AA1C4
Jan 01 05:46:52: INFO: Bitrate: 20780 Kbit/s
Jan 01 05:46:52: ERROR: Scrambled: 1011=1255 1012=88
Jan 01 05:46:53: INFO: Bitrate: 25410 Kbit/s
Jan 01 05:46:53: ERROR: Scrambled: 1011=1822 1012=128
Jan 01 05:46:54: INFO: Bitrate: 25358 Kbit/s
Jan 01 05:46:54: ERROR: Scrambled: 1011=1815 1012=127
Jan 01 05:46:55: INFO: Bitrate: 23089 Kbit/s
Jan 01 05:46:55: ERROR: Scrambled: 1011=1657 1012=116
Jan 01 05:46:56: INFO: Bitrate: 25405 Kbit/s
Jan 01 05:46:56: ERROR: Scrambled: 1011=1820 1012=127
^CJan 01 05:46:57: INFO: [main] shutting down
OK, looks like you've made progress. Without you giving us any sort of information on what you're stuck on, it difficult to advise further.
Start from step 5 .....
4Himdj
1.2 Laminas Dish
Rome
hello it's seems on air 3 t2-mi trasponder on 36east (sub saharian beam) that I can catch from Rome.
I've SF4008.
can someone help me what to insert in astra.conf and lamedb in order to catch that trasponder, please?
what parameters could helps?
an italian forum user gave me some screenshot from t2-mi analyzer
thank you best regards
Which transponder?
4Himdj
1.2 Laminas Dish
Rome
I put the only 2 it seems I could receive
12418 V 31420 (stream 105 & 106)
12379 V 31420 (stream 101)
ACM/VCM
Sadly no signal here. Can only receive 12054 and 12245 on that beam.
MCelliotG
Thessaloniki, Greece
I don't understand, why don't you follow the instructions as I wrote them, I think they are pretty clear....
Scan the TP, see if there's a data channel that downloads, copy its service reference, modify it to TV on Dreamboxedit and analyze the stream!
None of us seems to have reception of these frequencies!
4Himdj
1.2 Laminas Dish
Rome
hello mcelliotg. just because I'm very new to this procedure and I didn't understand I need to scan trasponder first, even if my SF4008 dont' scan t2-mi directly
sorry to annoy
best regards
Unfortunately you are pretty much on your own with these transmissions - they are unavailable to the majority of our members who are in NW Europe.
4Himdj
1.2 Laminas Dish
Rome
hello I can receive some trasponder from that african beam (e.g. 11843 or 11938 just for example)
another italian user receive 2 out of 3 tp
I need to try that specific t2-mi trasponder another time because wind is strong on these days and my motor system have problem with it...
regards
evans
1.8M solid pan motorized
strong srt 4669x
somanya,Ghana
Hi guys,
I have been trying to get multistream @ 36e (sub-Saharan beam to work)
the same beam reported by 4Himdj
Am using Zero 4K
this is my stream analysis
login as: root
root@vuzero4k:~# astra --analyze "t2mi://#t2mi_pid=4096&t2mi_input=http://127.0.0.1:8001/1:0:1:320:3A2:0:168B083:0:0:0:"
Nov 19 14:59:06: INFO: Starting Astra SM 0.2
Nov 19 14:59:06: INFO: [t2mi/analyze] L1-current: PLP 0 (Data Type 1), group 1 (*)
Nov 19 14:59:06: INFO: [t2mi/analyze] L1-current: PLP 1 (Data Type 1), group 1
Nov 19 14:59:06: INFO: [t2mi/analyze] L1-current: PLP 2 (Data Type 1), group 1
Nov 19 14:59:06: INFO: [t2mi/analyze] selected data PLP 0 (auto)
Nov 19 14:59:06: INFO: PAT: tsid: 10
Nov 19 14:59:06: INFO: PAT: pid: 16 NIT
Nov 19 14:59:06: INFO: PAT: pid: 32 PMT pnr: 3001
Nov 19 14:59:06: INFO: PAT: pid: 219 PMT pnr: 4250
Nov 19 14:59:06: INFO: PAT: pid: 223 PMT pnr: 4260
Nov 19 14:59:06: INFO: PAT: pid: 217 PMT pnr: 5240
Nov 19 14:59:06: INFO: PAT: pid: 221 PMT pnr: 5250
truncated........
Nov 19 14:59:07: INFO: SDT: Provider: MCA
Nov 19 14:59:07: INFO: SDT: descriptor: 0x4904FF5A4146
Nov 19 14:59:07: INFO: SDT: sid: 7055
Nov 19 14:59:07: INFO: SDT: Service: Emmanuel TV
Nov 19 14:59:07: INFO: SDT: sid: 7351
Nov 19 14:59:07: INFO: SDT: Service: Star Life
Nov 19 14:59:07: INFO: SDT: sid: 7058
Nov 19 14:59:07: INFO: SDT: Service: Go Channel
Nov 19 14:59:07: INFO: SDT: sid: 10000
Nov 19 14:59:07: INFO: SDT: sid: 10010
Nov 19 14:59:07: INFO: SDT: sid: 10020
Nov 19 14:59:07: INFO: SDT: sid: 10030
Nov 19 14:59:07: INFO: SDT: sid: 10040
Nov 19 14:59:07: INFO: SDT: sid: 2110
Nov 19 14:59:07: INFO: SDT: sid: 10017
Nov 19 14:59:07: INFO: SDT: sid: 3001
Nov 19 14:59:07: INFO: SDT: sid: 6110
then my astra.conf
log.set({ stdout = false, debug = false, syslog = "astra", })
f12419mca0 = make_t2mi_decap({
name = "12419V T2-MI",
input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:168B083:0:0:0:",
plp = 0,
pnr = 0,
pid = 4096,
make_channel({
name = "12419plp0", input = { "t2mi://f12419mca0", },
output = { "http://0.0.0.0:9999/mca/12419plp0", },
also attached is Dreambox edit showing the bouquet I created
However, am just testing one channel "Emmanuel TV" and it's not working, please help correct what am doing wrong
I cant see any info about a t2-mi stream on 12419v 36E. Are you sure its there? What source are you using?
BTW congratulations on your first post after almost 9 years membership :) :-welcome1
evans
strong srt 4669x
somanya,Ghana
it's not listed on lyngsat or flysat or any other, but it does exist, I was able to scan it with my octagon 88+
hehe, thanks for having me
It must be fairly new as Lyngsat dont have it. Fair enough - as long as you know its there then its worth chasing. Its always worth us checking as we have had folks using out of date information in the past - then wondering why the channels they are expecting arent turning up!
EnoSat
enosat.euweb.cz
Slovakia
fix lamedb for DATA channel and satellites.xml for multistream on 12262V , 12379V , 12418V - Africa T2-MI
evans
strong srt 4669x
somanya,Ghana
your post, not clear mate...please expound further...
Thank you
EnoSat
enosat.euweb.cz
Slovakia
read first post about Extra parameter
evans
strong srt 4669x
somanya,Ghana
thanks, mate for your fast reply
Extra parameters: add c:151000, where 15 is the cached index and 1000 is the hex value for 4096. This will cache this pid in the lamedb, and will provide all T2-MI data.
I used 151000, where did I go wrong? I though 151000 is a standard
evans
strong srt 4669x
somanya,Ghana
hehe, I figured it out, need to convert the PID to Hex
Since there is the paucity of information about the said transponder, how do I get the PID
thanks in advance
