New Lnb changer
4wd
Getting the picture
5 W, 9-13-19-28 E
wow, impressive. Congrats+++
dreambox1959
46.3N-4.3E-FRANCE
france
I wake up this post because i am finalize my positioner software .my friend Cardiff has build an lnb changer and i manage this device with my positioner !
i put east west and store command in diseqc 1.2 mode.
what is Go to Reference Position -- E0 30 6B 00 for ?
where is reference point , middle or limit ?
From memory, 'E0 30 6B 00' is the centre position for the motor, it is not a 'go to 0 degrees / true south', and does not relate to a specific satellite.
The parameter byte ‘00’ (i.e. Satellite Position 0) is reserved as a “referenceposition” which is not valid for storing satellite position data. However, someapplications may require a specific command to Enable (Soft) Limits, so allMasters (i.e. Tuner-receiver/IRDs) should be capable of transmittingcommand ‘6A’ with a data byte ‘00’, either specifically as an “Enable Limits”user-command, or by allowing“Position 0” to be selected for the “StoreSatellite Position” installation command.
M / T - 6B - Goto nn / Drive Motor to Satellite Position nn
Trust
Nijmegen Netherlands
I do love to to see pictures of that lnb changer
Trust
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
Hello,
Trust has designed and built this Lnb Changer for a satellite dish Laminas 180, Trust helped me a lot in assembling and adjusting the Lnb Changer and for many other things, I thank him again.
I increased the rotation of the disecq "rotor" to about 350 °
Cardiff
Trust
dreambox1959
46.3N-4.3E-FRANCE
france
does Trust and trust1 are the same person ?
for Trust or anyone who know :
on diseqc motor , when we select "goto 0" does the motor go to 'mechanical south ' or on a preset position?
in some notice it s write "go to pos 0 with east/west buttons and press reset" , does this way erase limits ?
do i have to set them before anything else ?
BR
dreambox59
Trust
At most boards my name is Trust , for some reason I could not register here with that name , so I used Trust1
When you select Go to zero or Reference , the rotor moves to a mechanical switch at the zero position .
At some rotors thats automaticly a reset , but has no effect on the limits you activated before
Mod. Note
I've checked the Members' list and the name "Trust" is not in use - would you like to change to that? If so, suggest you PM @Analoguesat or @rolfw :cool:
Edit: I see it's all sorted :)
dreambox1959
46.3N-4.3E-FRANCE
france
trust or someone else ! Did you read firmware in rotor or positionner ?
On different view about Diseqc Motor internal pictures its seems it’s the same chip!!
I tried to read the holtek 48r50 but unsuccessfully.
i am curious to see how they have managed diseqc command .
Trust
I dont have the equipment to read those chips , just use a old Maxplus 2100 receiver to control my lnb revolver
Trust
dreambox1959
46.3N-4.3E-FRANCE
france
thanks Trust !
i know very well all the basic diseqc command , in case of rotor (lnb changer) there is very few informations about gotox.x command :
as i see on my receiver it s different from eutelsat datasheet ! (eutelsat says "Command byte ‘6E’ is not yet fully defined" !!
about lnb changer Cardiff said to me he had removed the limit switch and limits are not managed anymore.
i had put another question on this thread:
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
...about gotox.x command :
There are indeed two types of GotoX commands.
Tested in this thread: USALS/ GotoX; Raw diseqc commands
Or in the parallel dutch thread: USALS/ GotoX, Raw diseqc commands
Copied from satelliteguys:
The GotoX command always starts with E0 31 6E ..,
in the dvbdream program I notice that two different ways are used to turn left or right from zero, for different diseqc motors:
motor:_______________________to the left (+ no. degrees)____________to the right (+ no. degrees)
STAB and SM3D12____________Ex xx_______________________________Dx xx
SG2100_______________________Ex xx_______________________________0x xx
Geotrack H120 and generic____Fx xx (counting back from FF FF)____0x xx
(For the test results: see the links...)
greetz,
A33
