Noob looking for direction
Faser3033
Technomate dish and techno mate tm5300d+ m2 super+
London
Today i found a bag with two satellite recievers one being a techno mate tm5300d+ m2 super+ i also have a dish on my house that says 'technomate' not sure if its motorish? Does this matter? How can i find out?
Also is it worthwhile my time even messing with this box? Its it outdated tech or can i get free channels of this thing
If so can you point me in the right direction please
The boxes have two cards in them they say 'viaccess.orca'
Aaron
Mickha
North West
You can still buy the Technomate TM-5300 D M2 Super+ Digital Satellite Receiver, so it should be capable of receiving quite a few channels.
Is there a cable, from the dish, going into the house?
If possible please upload some pictures, of the dish/LNB, and check if any cable is still alright, and not damaged.
I have a couple here, requiring remotes but they are/were good as standard definition receivers.
A completely different menu structure from the other TM receivers I have used though (1500/5402/6800)
Faser3033
London
I have the cable from the dish running into my house. It seems good. Ill upload a picture of the dish tomorrow for you
Thanls
Faser3033
London
20191211_123957-jpg.127386
... interesting
Mickha
North West
The cable, and dish, look fine.
I'd try connecting your receiver, to the incoming cable, and check what channels scan in.
Faser3033
London
Thanks for the input.
I will plug it in tomorrow and see what happens
Faser3033
London
Is it a motorised dish??
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Well, I don't see a motor through the perforations of the dish.
But it is not 100% clear; a photo from the side would be better for that.
greetz,
A33
Faser3033
London
Ok i will take a better picture
Does it matter if it is motorised or not?
Mickha
North West
All a motor does is move the dish so that it tracks the satellite arc, so you can view more satellites, generally from 30W to 52E.
Once you do a scan we'll be able to find out which satellite your dish is pointing at, probably 19.2E, 13E or 28.2E.
I don't see a motor there, but if the receivers are already sending data that activates movement on a different system, the dish might not pick up any signal.
Faser3033
London
Hi sorry for the late reply i did a scan and only got free channels on 13e satellite.
It found 230 free to air channels but how do i get the encrypted ones.
I checked the other satellites of which some had good signal but none of the others found any channels
My card is via access but none of those channels scanned
Is the card up to date?
Is the subscription still valid on it??
Is the channel list up to date? Channels move around.
Are you pointing at the right satellite?!
Lets start with
Which service is your viaccess card valid for
Faser3033
London
Not sure i found the box and the card.
Not sure how do i find this out
I did a scan and it picked up 230 free to air channels these are up to date a working but i didnt pick up any encrypted channels
Im guessing its pointed to the 13e satellite as im getting 230 free channels on there
127436127440127441127437127438127439
Take pictures of the card including the subscription number
Mickha
North West
Those signal quality readings are poor, which possibly means that the dish has moved, and might explain why you're not getting all the channels.
Can you please post some of the channels, you're able to view, along with the transponder, polarity, and S/R (Symbol Rate)
e.g. Fashion One Europe 10815 H 27500 DVB-S
https://www.lyngsat.com/Hotbird-13B-13C-13E.html
