Receiving 2 satellites with 1 degree difference on same lnb
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Hello,
Has anyone ever tried if it is possible to receive two satellites with an offset of one degree on the same LNB?
For that: is it possible to receive Eutelsat 9e and 10e on the same LNB with a triax 88?
Thanks in advance!
Yup with a big enough dish its easy. You will need at least a 1m dish though as 10E is quite a bit lower power than 9E.
Not just 1 degree either - Ive has the heavily inclined 20W as a bonus on a 22W lnb. A better example of 5E & 3E on an 80cm dish aimed at about 4E.
Hello,
Thanks in advance!
Yes.
Motorise it.
One of my carefully aligned fixed 90cm dishes (which is slightly larger than a TD88, which I also have, as well as a TD78 and a TD110! :D ), and using the same LNB. is pretty good for both 9E and 10E with the SX88/88+ - although, of course, I get more channels with either of the larger steerable dishes. Thus the TD88 should work for both sats for the stronger transponders - although only after very carefull azimuth/elevation/skew alignments as even a "very slight" error in any of those then it won't work as well.
OTOH, if I was using the TD78 (in reality not much larger than a decent 60cm dish :( ) instead, then the results would be "poorer" - especially on 10E - which is why it's not used for those sats.:rolleyes:
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Thanks for the reply’s!
First of all: motorising isn’t an option as the dish feeds 3 receives.
Now this dish has 5 LNB’s: 19e 13e 9e 4.8e and 0.8w so I guess it won’t be that easy to align it for reception of 9e and 10e and still being able to receive the other satellites?
All my LNB’s are now standing against each other without space in between them. With the exception of 0,8W which has a little bit of space.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Please show us a picture like this:
Nalleman
Motala Sweden
Sweden
Hello,
Thanks in advance!
I'm getting 9E and 10E with an old 1,8 m dish. No problem at all.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
If that is the case, also with 13E and 19E (6 degrees arc), then 13E-10E will be difficult (just 3 degrees arc)!
You'd probably need a dish with a greater focal distance ~ so basically a bigger dish for that.
Or use 2 dishes, and divide the LNBs over them (28-19-13; and 9-5-1W).
Greetz,
A33
LeBelge
Belguim
Or T90 Toroidal Satellite Dish
