Eutelsat 7C
Spectrum between 23:22 and 4:10 (CET time) on 27-28 January.
You can see all the transponders turned off and then on again.
Link: MEGA
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
Eastern Beam Reception:
sector_d
Portugal
Octagon SF4008 with RTL usb DVB-T Tuner
Clarke Tech 5000 (semi-retired), X-trend ET-9200 (semi-retired), Nokia 9600 :) (well retired)
Portugal
Good afternoons I have a doubt about the Eutelsat 7C Ku-band Western Downlink in which it says on the flysat that the frequencies of digiturk are in this beam and why I here in Azores with the 2.40 m dish I don't catch anything only the frequency 11221H that also says that this in this beam, the frequencies of the digiturk are in the Eutelsat 7C Ku-band Eastern Downlink
View attachment 128429View attachment 128430
Hello,
I'm on Portugal West Coast and after tonight the signal in Digiturk transponders raised a little (now around ~14 dB snr from previous 12 dB ). It doesn't seem to me as in the Eastern Beam. But then again, those TPs signalled in Flysat as Eastern Beam's come in fairly well too, with ~13.5 dB snr.... I have 240cm.
ocean04
Vaasa
Western Finland (63N 22E)
Signals have improved slightly here in Finland.
11046H, 11192V and 11221H same as before, likely not moved and are 7B
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
Good afternoons, something doesn't quite fit with the beams on the flysat. I pick up in the azores the 2 frequencies of the Eastern beam 11045 H and 11192 V and the Western beam the frequency 11221 H and no digiturk.
Strange with the attribution of these beams by flysat?
128443
128444128445
ocean04
Vaasa
See my post above. These are 7B
sector_d
Portugal
Portugal
View attachment 128444View attachment 128445
FYI, at this moment I receive 11046 with 12.5 dB snr and digiturk transponders with ~14.5 dB snr, at my location.
WaferSat
Laminas OFC-1200P, 30w-46e
Southern Finland near Helsinki
Yes, I agree, southern Finland near Helsinki, Before and After, 120cm dish
EDIT: new revised results
128447
No signal here now on 11575 V ?
It looks like this has moved to 11553 V 29750 Irdeto-T2 ? may be UHD as it ended up on my Radio list no audio atm may be a test like Irdeto _T5 on 11595 H 30000 ?
I will have a Blind Scan with the A4K :)
Ahmed-Iraqi
Icone HD Receiver , Starsat HD Reciever, Sky Star HD USB, EuroStar Dish 90 cm, Televes LNB
Iraq
11553 V has worked instead of Freq 11575 V​
D6
D.Shimoni
Hendrik
28.01.2020​
11575 V
DVB-S/MPEG-4​
DigiTürk
package
left​
MCelliotG
Thessaloniki, Greece
Just checked the signals, not exactly what I had expected with a 1.30 dish within the 51dbW footprint! Frequencies after 11300 are good from 15.5 to 17.5db, but lower TPs are around 12.5 to 14db, that's lower than expected.
D6 waek need Israel 1.8m
We have confirmation Eute 7A will be relocated:
EUTELSAT 7A will be transferred to another orbital location as part of Eutelsat’s fleet optimisation strategy.
5 west looks like odds on for E7A next assignment :):Y
EBSpro_7.0E,all transponders found atm in my area.
let see if it stop 139w or 5 w
the 7b also move 7c same transponder bicose it have 49 tp
