Channel master smc 3.0m pf restoration
khaled cr7
astra 19.2
jordan
So after scanning the skies with my ku rig I realized that here in Canada most of the permanent backhauls I wanted were on C-band :-doh! I found a 3.0M PF antenna an hours drive away. The first 3 pix are where it was. A couple of weeks ago (after lots of procrastination and hesitation) I took it down off the pole and carted it home. I got really lucky cuz it only started snowing after I got home. Most of the coating over the metal mesh was gone since the antenna is 25 years old. Gave it a thorough cleaning with a hot water/bleach/soap solution. This revealed that around the outer edges of a couple panels the metal mesh was missing. The worst is a 4" gap. So I am attaching aluminium screen door mesh in those places. I realize it's not perfect but my prime goal for this antenna is C-band not Ku. All four panels are getting a couple of coats of resin then sanding and painting.
My satellite view in my backyard is blocked by my neighbours trees so my best solution is to mount it above my roof. More pics to come as the restoration/installation progresses.
Hello
Do you advise me to own such a dish?
I found it from an old person
Channel Master SMC 3.0M dish
How much dBi ku earn
Is it this type ?
khaled cr7
astra 19.2
jordan
Is it this type ?
Yes the same type 3 meter
How much is the ratio of dbi
Is Channel Master 3.0M better than DH 3 meter dish
A picture of the feed the seller has been using will determine what it is good for.
khaled cr7
astra 19.2
jordan
هل طبق Channel Master 3.0M افضل من طبق dh 3 متر
after search Channel Master 3.0M
49.0 dbi
Not as in the picture 53.5
  • Channel Master 1611_001.pdf
49.0 dbi
You don't need help then.
Good luck with the purchase. :Y
