Es'hail 2 25.8°E channels
Stejc
DM800, Motorised Triax TD88, 45W to 39E. Digital+ HD subscription, TNTSAT HD Card.
Southport
How are the beams for the broadcast channels on Es'hail 2 at 26E? Are they as tight as for its sibling at 25.5E?
Any reception in Europe other than Southern Europe?
ocean04
Vaasa
Western Finland (63N 22E)
Curretly 3m + SF8008
10730H 6.0db
10850H 8.0db
10890H 7.5db
11350H 4.8db
(Eshail 1 nothing here)
Stejc
Southport
10730H 6.0db
10850H 8.0db
10890H 7.5db
11350H 4.8db
Thanks, sounds promising. I might try it on my fixed 1.8m in the UK as my motorised has 26E blocked by trees.
...I might try it on my fixed 1.8m in the UK as my motorised has 26E blocked by trees.
From a Southern UK location I managed to lock two of the frequencies when I tried a few months ago. A couple of the others were present but not with enough signal to get a lock. The bein sports one was quite strong at the time I did the test and I managed a lock on it.
Picture attached below.
Stejc
Southport
Thanks. I'm further North so might have less luck! BeIN are moving more channels over to it at the moment and all with 2/3 FEC which will be more favourable (see attached).
I have an official BeIN box and subscription on Nilesat and about 7.2db seems to be needed for lock and about 8db for a solid signal, the subscription works on Es'hailsat too so it would be good to try it on there.
dreamsat
germany
my reception from saxony in germany with 3,7m
dreamsat
germany
10890 V 27500 2/3 VA 220 Test Card
dreamsat
germany
10850 V 27500 3/4 QPSK "Al Jazeera Channels "
dreamsat
germany
today is the reception better
Yes those frequencies that @moonbase posted look familiar to those I managed to lock on Esh2. Nowt from Esh1 - southern England seems to be in a null for it.
dreamsat
germany
10730 H 30000 3/4
dreamsat
germany
Today four transonders go
beIN Sports mux on 10930V, SR27500 locked from Surrey, UK location
Stejc
Southport
Stejc
Southport
Yes. got all 6 of them from 25.8E
Thanks. If they move more channels to 25.8E then I might even give it a try (although without holding up much hope of getting much).
If you ever need an official BeIN receiver to try let me know as I have a spare with a subscription that can be activated.
dreamsat
germany
my reception
the 11310 V 30000 is the weakest transponder in this area
jambon550192
Paphos cyprus
1m orbit h2h manhatton plaza cm1.8 inverto quad with cm feedhorn at 7w,tm 6900 super hdfixed 1.5 prime focus on 16e with tring diseqc x4 at 7w v/h 13e 19.2e 28.2e with 3 quad smart titanium gold 0.1 lnbs ,TM-3000d 2.5 precision at 25.5e
kent
Hi do you still have the bein receiver?
