Ka-Band Satellites
I'm unwilling to climb up to my Gibby to change the LNB to a Band A for Turksat 4A, as I don't fancy visiting A&E during this time of pestilence if I break a bone. So I recovered from the back of the shed an old Sky dish, the 60cm perforated job.
Rusty, but fits the bill.
I'm limited in convenient places that can find 42E at ground level, so I've wedged it between the garage and shed.
The FD9000 feedhorn needed a dielectric card inserted into the throat to convert left hand circular to linear suitable for the Norsat to increase the signal to lockability.
@John - No Dominium City Global Tv Test at present, presumably random tests come and go with this mux feed?
For tests, I'm using an RPi4 with updateDVB on an ArchLinux build. No mosaic of the mux with that, so I'm using 4T2 Analyser there.
... Love it Llew, seems to be working very well
'MAJESTY TV TEST' has been part of the 6ch mux for a few days but only seen a black screen up to now
Thanks John, as the dish is fixed on that KA beam, I can check the mux for changes more easily.
My DRO modded 9E Saorsat KA LNB seems to work well on the dish too (reversed spectrum puts the beacon to the right of the mux).
Turksat 4A KA 18668L. New channel on 53202. Replaces Majesty TV.
Info: - 16° East Ka.
As from approx late afternoon UK time freq 21.534 H - - 'Vision 4 - RCA' appears to have left it's frequency slot
... she's playing tricks Llew , she's back up and running this morning
Oh well, we all have off days I suppose. Keep 'em peeled John :)
Turksat 4A KA 18669L New channels, SID 53206, 53207. Or are they merely returns?
Turksat @ 42° East.
Up to eight things running now on 18669 LHC.
What sort of dish size is needed for Ka on 42E?
For that particular LHC frequency from 42°E here 17miles north of Nottingham, i'm using a 1.2 Gibertini with a modded Gilat ODU lnb mated to a Hughes Ka poloriser.
I recon if the signal stays at this regular strength then 80cm upwards should suffice.... I think Llew had it all ok recently on a 80cm or similar.
Although iv'e not shown the strength on that simple shot, it's showing 12dB C/N.
Just an observation -
Ka - 18GHz ITN Newsnet - - 18.557 V.
Not very often you see the Newsnet scene totally empty of people & all equipment / monitors switched off.
Creepy :-ohmy
None of the usual coats, drinks etc.
... back to normal this morning
SimonE
Gloucestershire, UK
Lots more signals on Turksat 4A Ka. 5 muxes running there now.
A little too weak for me with the 60cm dish. Only the Turksat Promo locking on 18590V.
[/QUOTE
Can you just remind us again Simon what lnb and dish you are using for 42° E
Re: 42 East Ka ....
Can't make my mind up if the signal around 18705 L is two small ones or not
