My Dish From Greece
What happened when you tried a manual reset procedure on the original motor ?
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
So, i managed to setup the motor at 23.5 east, and tightened the brackets, will test the arc tonight and see how well i've done :)
stel883_
Vátika, Greece
I did reset a couple of times, tried different receivers to get it working, but it got stuck at zero.
stel883_
Vátika, Greece
This is the transponder i set it up with, 12187 H 29900 - REBEL. Credit to william-1 for his work on strongest transponders :)
MCelliotG
Thessaloniki, Greece
And even that is not correct since Vu stops at 17db. So you don't actually know if the value is full and goes above that... You should also try the weakest transponders.
stel883_
Vátika, Greece
I am using Axas E4HD combo, for the motor movement. After trying to setup with diseqc 1.2, i was going from zero to 13 east, so i decided to try usuals, i put in my longitude and latitude and it worked!! I have successfully moved to 34.5 west and stopped there, 65 on the motor. However only 22 west clears channels, i must have some blockage from a palm tree :(
stel883_
Vátika, Greece
Edision OS Mini 4k
stel883_
Vátika, Greece
I also successfully moved to 74.9 east, 55 on the motor. However only 70.5 east clears channels, i'm using vhannibal motor settings atm. I think for first time setup i'm quite happy :)
stel883_
Vátika, Greece
Do you mean the tuner is not reporting correctly? Weakest transponders to maximize the signal, i did with static dish, for motor since this was my first install, i used strongest to get it going, because night-time came :)
stel883_
Vátika, Greece
Some pictures of new motor installed! 23.5 east, motor at zero.
Is there a difference, lower or higher on the shaft to attach dish?
stel883_
Vátika, Greece
I installed a new satellites.xml according to my Co-ordinates, plus some new settings from chveneburi, and i managed to move the dish to 90 east, and clear some channels :)
stel883_
Vátika, Greece
MCelliotG
stel883_
Vátika, Greece
Hi, in my 90 east report, i was using 2nd tuner on the Axas E4HD combo, so i can use the loop-through. Which has a higher signal in db, so i used Edision OS Mini 4K this time.
I can only receive these channels. Used OpenWebif to get data :)
  • edision_os_mini_4k-90e_scan.txt
MCelliotG
Thank you. These are more realistic db values for this satellite, because I saw you had 12db and was very surprised.
stel883_
Vátika, Greece
O.k i'm back to Vhannibal Motor 70°E-45°W, clearing 22 west to 70.5 east.
I'm still hoping to get 30 west, with maybe another dish mounted elsewhere!
stel883_
Vátika, Greece
After moving the 1 meter dish to a new position, i managed to clear 30 west channels! My friend who is an installer told me, i had not correctly aligned the dish on the moteck sg2100a before.
That's a heck of a range! 90E to 30W... and I struggle to get beyond 50E here. You should be able to get up to 58W but that's C band only area.
stel883_
Vátika, Greece
My co-ordinates give me 53 west to 100.5 east, don't know if this possible?
